NA vacuum pressure, Quick Question |
Oct 16, 2006 - 1:34 PM |
I've happend apon a cheap boost gauge that messures up to 30+ & -. I'm wonding if this is enough to messure the vacuum pressure. I'm worried that it won't. I just want to know the deference in pressure as the rpms go up or down.
Oct 16, 2006 - 5:00 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I'm not sure if its the same for all cars, but my friends GTI has stock turbo and he installed a boost gauge on his. He said its suppose to read -20 when idling and yes it goes to 0 when he is accelerating and depends on how much gas he gives it.
(but his goes to 10psi cuz its boosted) but I believe he did install it on his stock Mazda which wasn't turboed yet and it would go to about 0 when accelerating.. I have a Vacuum gauge coming and if I can get it installed easily, i'll let you know what I find out Thanks! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 16, 2006 - 5:49 PM |
I had a feeling it was around that. That's what I've seen on my buddies 240. A good bit of negative just at idiol.
Oct 16, 2006 - 6:48 PM |
at warm idle, a 5sfe should see between -18 - -22 just FYI, bulldog
13.6@108MPH, 5SFTE Powered |
Oct 16, 2006 - 7:18 PM |
do you all have a pic of how to run the hose to read the vacuum? i'm not sure how to do that when i get the gauges...
what about the volt? thanks! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 16, 2006 - 7:48 PM |
QUOTE(presure2 @ Oct 16, 2006 - 7:48 PM) [snapback]492410[/snapback] at warm idle, a 5sfe should see between -18 - -22 just FYI, bulldog Do you think I would just snap the gauge if I put it on there like it is? Or would it just max and that be the end of it? QUOTE(Jaws4God @ Oct 16, 2006 - 8:18 PM) [snapback]492415[/snapback] do you all have a pic of how to run the hose to read the vacuum? i'm not sure how to do that when i get the gauges... what about the volt? thanks! I will let you know as soon as I put it on. I might even strap a leaf blower on there to see if I can create positive pressure, just for kicks. I'm also going to test my ram air system, vs just my short ram intake. I hate how those are named the same. I think this gives me the chance to really play with things. EDIT: Jaws, what do you mean by volt? Do you mean my volt gauge? Because I don't have it on yet either. If you're talking about power to the gauge, I'm just going to tap into the fuse box and use the gauge light fuse. This post has been edited by Bigmeanbulldog55: Oct 16, 2006 - 7:50 PM -------------------- Live Free, Be Happy
Oct 16, 2006 - 8:00 PM |
QUOTE(Bigmeanbulldog55 @ Oct 16, 2006 - 8:48 PM) [snapback]492422[/snapback] QUOTE(presure2 @ Oct 16, 2006 - 7:48 PM) [snapback]492410[/snapback] at warm idle, a 5sfe should see between -18 - -22 just FYI, bulldog Do you think I would just snap the gauge if I put it on there like it is? Or would it just max and that be the end of it? QUOTE(Jaws4God @ Oct 16, 2006 - 8:18 PM) [snapback]492415[/snapback] do you all have a pic of how to run the hose to read the vacuum? i'm not sure how to do that when i get the gauges... what about the volt? thanks! I will let you know as soon as I put it on. I might even strap a leaf blower on there to see if I can create positive pressure, just for kicks. I'm also going to test my ram air system, vs just my short ram intake. I hate how those are named the same. I think this gives me the chance to really play with things. EDIT: Jaws, what do you mean by volt? Do you mean my volt gauge? Because I don't have it on yet either. If you're talking about power to the gauge, I'm just going to tap into the fuse box and use the gauge light fuse. everything will be just fine. you'll never see more than -25 or so. -------------------- Former Team 5SFTE pro member ;)
Oct 16, 2006 - 10:52 PM |
Enthusiast Joined Sep 1, '06 From Michigan Currently Offline Reputation: 0 (0%) |
bulldog, please post your results when you get them. THats a good idea man.
Oct 18, 2006 - 6:10 AM |
Enthusiast Joined Apr 10, '06 From indiana Currently Offline Reputation: 0 (0%) |
I've got a boost/vacuum gauge on my 90 5sfe gt. At idle throttle it reads nearly -30psi. Full throttle is always 0psi. I have a ebay cold air intake sucking air from custom hood scoop. No box, so won't get ram-air, but it is a very short length of pipe and it keeps the intake manifold nice and cool.
Oct 18, 2006 - 9:17 AM |
QUOTE(CarneDeBlaQ @ Oct 18, 2006 - 11:10 AM) [snapback]493076[/snapback] I've got a boost/vacuum gauge on my 90 5sfe gt. At idle throttle it reads nearly -30psi. Full throttle is always 0psi. I have a ebay cold air intake sucking air from custom hood scoop. No box, so won't get ram-air, but it is a very short length of pipe and it keeps the intake manifold nice and cool. Do you have a picture of it installed? i'm still wondering what line to tap into to get the reading.. -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 18, 2006 - 10:31 AM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
If you need more, let me know.
oh Jaws, and about the volt gauge. You really dont have to make it all that complicated. Just hook it into the same source where you hook the postive wire for the guage backlights. Examples would be, cig lighter, or dimmer switch. As long you make a real good ground, you'll be fine. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Oct 18, 2006 - 1:57 PM |
Hitcachi's location is fine, but you can hook it up anywhere off the manifold. I eliminated all emmisions crap so I had some extra places to plug into.
Oct 18, 2006 - 3:11 PM |
Cool!! thank you hitcachi thats exactly what I was looking for!
So how did you run it throught he firewall? I just thought of that :-P -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 18, 2006 - 4:19 PM |
the boot for the steering rack and pinon. Props to Dustin for letting me know on that one a long time ago
Oct 24, 2006 - 12:21 AM |
well i got them installed today.. but little confused.. looks like the vacuum will read about 22 when idling.. and when i gas it it jumps down closer to 10 or 5.. but I thought if I left the gas there then the vacuum will stay there.. IE, the more gas the less vacuum...but if i give it steady gas it seems to jump down to 10 ish then go back up to 20.. is that normal?
i'll drive it tomorrow to see how it does.. -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 24, 2006 - 2:08 AM |
Enthusiast Joined Mar 17, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(Jaws4God @ Oct 24, 2006 - 1:21 AM) [snapback]495357[/snapback] well i got them installed today.. but little confused.. looks like the vacuum will read about 22 when idling.. and when i gas it it jumps down closer to 10 or 5.. but I thought if I left the gas there then the vacuum will stay there.. IE, the more gas the less vacuum...but if i give it steady gas it seems to jump down to 10 ish then go back up to 20.. is that normal? i'll drive it tomorrow to see how it does.. 22 inches at idle is good. When reving a parked engine a rapid return to high intake manifold vacuum (above readings at idle) is normal. On the road the engine will give the readings you may anticipate due to engine load and vacuum characteristics. As you drive with Wide Open Throttle (Accelerator fully depressed) there will be virtually no engine vacuum. Zero inches indicates that there no difference between the normal atmospheric (outside the engine) pressure and the pressure (within the engine) at ported intake manifold source. However as rpm increases at part throttle vacuum #'s will rise (unless the engine is at W.O.T.) The extreme case is when you downshift and let off the throttle the readings will read somewhere around 30 inches until engine rpm decreases and/or the throttle is opened. You'll soon see this as you drive and watch the readings when you drive. The vacuum gauge is a good diagnostic tool. It can indicate if an engine is running properly. Many common engine problems can be discovered/ noticed and then diagnosed with the aid of a vacuum gauge. Yellow94GT This post has been edited by Yellow94GT: Oct 24, 2006 - 2:09 AM |
Oct 24, 2006 - 7:52 AM |
QUOTE(Yellow94GT @ Oct 24, 2006 - 7:08 AM) [snapback]495384[/snapback] QUOTE(Jaws4God @ Oct 24, 2006 - 1:21 AM) [snapback]495357[/snapback] well i got them installed today.. but little confused.. looks like the vacuum will read about 22 when idling.. and when i gas it it jumps down closer to 10 or 5.. but I thought if I left the gas there then the vacuum will stay there.. IE, the more gas the less vacuum...but if i give it steady gas it seems to jump down to 10 ish then go back up to 20.. is that normal? i'll drive it tomorrow to see how it does.. 22 inches at idle is good. When reving a parked engine a rapid return to high intake manifold vacuum (above readings at idle) is normal. On the road the engine will give the readings you may anticipate due to engine load and vacuum characteristics. As you drive with Wide Open Throttle (Accelerator fully depressed) there will be virtually no engine vacuum. Zero inches indicates that there no difference between the normal atmospheric (outside the engine) pressure and the pressure (within the engine) at ported intake manifold source. However as rpm increases at part throttle vacuum #'s will rise (unless the engine is at W.O.T.) The extreme case is when you downshift and let off the throttle the readings will read somewhere around 30 inches until engine rpm decreases and/or the throttle is opened. You'll soon see this as you drive and watch the readings when you drive. The vacuum gauge is a good diagnostic tool. It can indicate if an engine is running properly. Many common engine problems can be discovered/ noticed and then diagnosed with the aid of a vacuum gauge. Yellow94GT YOU DA MAN!! Drove it to work today, you were right.. it did what I expected... Thanks!!! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Oct 25, 2006 - 7:28 AM |
QUOTE YOU DA MAN!! Drove it to work today, you were right.. it did what I expected... Thanks!!! NICE! Nothing like an invigorating commute to make the day complete. Yellow94GT |
Oct 25, 2006 - 11:31 AM |
QUOTE(Yellow94GT @ Oct 25, 2006 - 12:28 PM) [snapback]495874[/snapback] QUOTE YOU DA MAN!! Drove it to work today, you were right.. it did what I expected... Thanks!!! NICE! Nothing like an invigorating commute to make the day complete. Yellow94GT just hope i don't wreck.. its so fun to watch it go from 25 at backpressure to 10 or 5 when I need to gas and go..to 20 when idling... -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:51 PM |
