11 Pages V  < 1 2 3 4 5 > »
> Build Thread 2006-07-08 3sgte. Its DONE!, Dyno Vid inside of Low Boost.
post Dec 10, 2006 - 10:55 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(playr158 @ Dec 11, 2006 - 12:53 AM) [snapback]509423[/snapback]
slim spal fans or place the fans in the front of the radiator instead of behind
(go push instead of pull)
true. i hope they clear the oil cooler behind the intercooler.
post Dec 13, 2006 - 5:49 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well the radiator i have now is pretty large its not stock. all aluminum and 30% larger than stock. also to keep heat low i think im gunna buy a turbo insulating jacket.
post Dec 16, 2006 - 5:19 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i just ordered a tial 38mm, when it gets here i take off the turbo elbow adapter i made, drill a hole in it, weld on the flange and bolt the wastegate on. soon though. thats my next project, getting the exhaust paths all setup with the WG.
post Dec 17, 2006 - 8:52 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
woo woo. got the valve springs in and cams. the toyotool is amazing and i recommend it to anyone. everything is assembled with arp moly lube to break the cams in properly.
ill get them degreed maybe tomorrow.
post Dec 19, 2006 - 7:46 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
woot, i wanted to buy a cheap ebay knock off but figured its way to much of a essential part to skimp on.
this weekend ill be making the downpipe and wastegate setup hopefully.
post Dec 20, 2006 - 11:57 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(yungazzdriver @ Dec 21, 2006 - 1:45 AM) [snapback]512067[/snapback]
what spring you got????? and tell me why i was thinking the same i was like.....hm the ebay one is soooo much cheaper but then i was like..........naw cant cheap out now because i havent so far and wastegate is essential at peak performance so i got the 10 lbs spring 38mm tial
word. i got the 1 bar: 14.5psi
post Dec 24, 2006 - 6:45 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i went and bought the stock to make the WG work, picking up the DP stock tomorrow hopefully, will be degreeing the cams tomorrow also. depends on what else is going on, holidays... Bah tongue.gif oh i also cleaned the bay out. im gunna go honda style and wire tuck everything and try to remove any pointless brackets or w/e from the bay. the ac system is all out now. gunna be respraying everything black Mmmm.
post Jan 7, 2007 - 10:58 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well, beeing working on the Wastegate and exhaust setup, got it mocked with rusty old pipe from my dads old exhaust lol. now i need to purchase some nice piping to make the final fit.
Polished up the RMR, holset comp side, and apexi bov with some jewelers polish i picked up at a world of wheels car show. they look pretty shinny now smile.gif
Started pinning the wiring harness and painted the hard plastic covers on the wires.
This week should be pretty productive im hoping. time is catching up with me now :x
post Jan 14, 2007 - 7:47 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
got the fuel line all set. but as a whole im still far from done id like to say i was closer but you forget about all the small things when i generalize and say its close lol.
like re wiring the harness and re-pinning it. or setting up vacuum lines, water lines attaching crap to the firewall. slower but surely, something about a turtle winning a race.
post Jan 21, 2007 - 2:39 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
V-band clamp will be in Tuesday. that dump tube will recirculate its really long right now, ill cut it down when the down pipe is finished so everything lines up perfect.
post Feb 6, 2007 - 3:48 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
haha nice pun tongue.gif ive been on a little break i think, well mostly just cleaning.
polished the intake manifold, took off the turbo compressor housing and sanded it till it was smooth no more orange peal texture just nice Bling polished aluminum. polished my old apexi twin chamber bov, yeah lotta polishing lol. my dad just picked up an industrial parts cleaning bin type tool, so i plan on soaking the the tranny, cross member, axels, ect and repaint em all. I need more motivation, I miss going fast.
post Feb 7, 2007 - 3:16 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
sure thing ill post pics when i get home. i was suckered into buying some metal polish at a car show, this guy polished the dome on the underside of a soda can and it looked like a mirror so needless to say i was amazed and ended up buying some. so i went on a polishing excursion lol. it came with a sealer polish also that when he put water on the dome it didn't want to stick at all, says the sealer um... seals it for up to a year and thats against most chemicals, water even anti freeze. but we'll see if it can take the temps of the engine bay. well see what happens.
post Feb 7, 2007 - 6:02 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
from that to this, pretty good i say. lotta work i gave up getting in the small crevasses but the silicon coupler that holds the filter on will cover that anyways tongue.gif
wow a flash really brings out the residue sealer wax that needs to be taken off.
post Feb 14, 2007 - 8:07 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
yeah ill post pics of the downpipe we've been working on.
post Feb 18, 2007 - 1:28 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
What ive been up to
downpipe is almost complete still waiting on the top and bottom vband flanges to welt to it.
thats why it was ghetto held up in the pics.
added some ebay bolt kit for the valve cover and other stuff.
got a 4" silicone coupler for the filter
painted the engine bay and started to tuck things like the air bag controller box and random brackets or w/e
not going crazy with it just trying to clean it up some.
oh and that bracket going to the turbo from the head will have another bracket along side it going to the ring along the exhaust side coming from the other ear on the head.
so it will be kinda symmetrical lol
This post has been edited by x_itchy_b_x: Feb 18, 2007 - 1:31 AM
post Feb 19, 2007 - 10:28 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(presure2 @ Feb 18, 2007 - 12:57 PM) [snapback]527982[/snapback]
nice work john!
good idea for the turbo stay, like dan said. i like it!
is the DP stainless? or are you planning on having it coated or somthing?
yeah i saw a similar bracket on mr2oc. I wanna support that thing any way i can.
we are also bracket that goes from the block to the underside of the turbo.
oh and the DP is stainless along with the v-band hardware, ceramic coated would be nice biggrin.gif know any one local?
QUOTE(alltracman78 @ Feb 20, 2007 - 12:00 AM) [snapback]528531[/snapback]
You're going to run and EMS and keep the dist?
Out of curiosity, why?
i havent really looked into what i would need to run coil over plug setup.
i realize the stock ignition isnt the best setup, but im hoping it will perform satisfactory.
if not id have no choice it seems.
post Feb 20, 2007 - 11:18 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
AEM ems. and i plan on 18 ish psi daily and 21 22 ish if it likes it at higher boost levels. yeah im hoping the hx35 will prove to be a good alternative to
post Feb 26, 2007 - 10:23 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
fun stuff ^
post Feb 28, 2007 - 12:04 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(95CelicaST @ Feb 28, 2007 - 12:16 PM) [snapback]531228[/snapback]
You must be RICH
The 5K loan was temporary wealth... but money well spent IMO
i have a feeling it wont be the last loan i take out for my car :X
horrrrrrible investment. but i dont treat it like an investment.
i get my money back tenfold in the joy i get from driving it.
post Mar 3, 2007 - 6:38 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Lo-Fi Version Time is now: December 3rd, 2024 - 3:14 PM
