> I think im about to blow up my celica!=(, Nology Hotwire Question
post Jun 30, 2003 - 6:48 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
OK...i just got my hotwires today..put them in no problem. But before i put in my last two wires i looked inside the boot and noticed a small amount of gel on the inside of the rubber hose that extends into the engine and to the spark plug. After i put all of them on i started my car up and WHOAH!! the damn thing sounds like a piece of crud old school bug thats about to break down. It sounds likes its running on 2 cylinders ( i dont know that for sure but its really spaced out and weak sounding) I started it...backed it up alittle...realized it had absolutely no chance of smoothing out...and pulled it back into the carport for further inspection...i checked everything and all my grounds are connected...is that gel posing a problem?? or is there something else im not doing? Please help...thanks alot.
post Jun 30, 2003 - 7:51 AM
Guest_Matthew_*
well if the gel was there before you installed new plug wires then i would probably so no its no the gels fault and to give him a break
i would double check to make sure that the wires arent broken inside ..
make sure that its properly connected at the distributor
or just back in your old wires and see if that works.
post Jun 30, 2003 - 9:28 AM
macavely
Joined Nov 4, '02
make sure you didn't cross you wire or you will have a dead cylinder.. just the problem sound like it the wiers.
post Jun 30, 2003 - 10:45 AM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
The gel stuff is inside the rubber boots that go onto the plugs right? That is supposed to be there. It is electrically conductive and stops corrosion and arcing.
macavely, you might be right about the crossed wires, else it could be one of the wires in not pushed on all the way. Check them all again and try it. If it still is rough, put the old ones back on. I have heard of the odd time that you get a bad wire out of the package. If it is rough with the old ones on, you may have disconnected something else. good luck!
post Jul 1, 2003 - 3:59 PM
TunerHawk
Joined Jun 26, '03
From Los Angeles
The gel stuff is actually a silicone based material, IT IS SUPPOSED to be there. This provides a 50% better connection rate and actually seals the two together, (not to tight, they will come off). But yes the gel (silcone) is suppost to be there and will not burn up.
post Jul 14, 2003 - 5:06 PM
DonMagicJuan
Joined Nov 20, '02
From Carson City Nevada
Sounds like you didn't connect the wires to the distrubuter in order. Try that I had the same problem and that how I solved it.
post Jul 15, 2003 - 1:28 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I think it is a common problem for the wire to disconnect from the boot when pulled on
it may have slightly separated
Lo-Fi Version Time is now: November 28th, 2024 - 12:29 AM
