![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) ![]() |
wen im goin straight it feels like my rear is swaying back and forth and i dont kno why could some1 help me with that??
This post has been edited by 2slow2nervous: Oct 17, 2006 - 1:41 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) ![]() |
What was in front of you? Or does it happen all the time. I know sometimes when i get behind a semi going fast his trailer will make my car sway a little.
-------------------- I'am Reinventing the SLow Lane.....
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) ![]() |
Check for wheel play (tie rod ends, ball joints) and get a 4 wheel alignment done
This post has been edited by bufferdan: Oct 17, 2006 - 2:02 PM -------------------- ![]() |
i was just driving straight and nothing wus in front of me... so i need a alighnment?
Enthusiast ![]() ![]() Joined Sep 1, '06 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
alignment. this happened to my van. once i hit about... 40 it was undriveable.
Enthusiast ![]() ![]() Joined Nov 21, '05 From Wpg, MB. Canada Currently Offline Reputation: 3 (100%) ![]() |
Make sure all your wheels are properly inflated. (32 or 33 psi).
Is there any play in your wheels? ie. if you kick the rear rims at the front and back, is there a clunking sound (and movement)? If so, it's related to suspension arms and/or bushings. If that doesn't work, go get an alignment and get them to check all your tires to see if any of them are separating/damaged. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
could even be as simple as tightening your lugs. my car didn't exactly sway but it shook unusually in the rear... one of my lugs actually fell off and the one next to it was almost gone. but yeah, try an alignment after you check the lugs and tire pressures
![]() Enthusiast ![]() ![]() Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) ![]() |
when my rear shocks died it was a bit stiry on the rear
-------------------- My Celica Is Now For Sale
thanks for the input guys helped out alot
Lo-Fi Version | Time is now: February 21st, 2025 - 8:19 AM |
