i need help, problems with the 3sgte swap |
Oct 19, 2006 - 2:47 AM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
the st205 tranny will only move about 1.5 inches out from the motor and then wont go any further
is there a trick in getting that all wheel drive tranny off of the motor????? i feel like crying... fro the past 24 hours ive been runing on 2 hours of sleep and i had class today. |
Oct 19, 2006 - 3:01 AM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
I don't think there is a trick. Just remember that 200lbs of tranny is pushing against the input shaftt. So at this point it's very dificult to slide off. Just make sure you are clear everywhere else one last time, and then push up from the bottom of the tranny to remove the stress on the input shaft. Shake it up and down while pushing it away from the motor, and little by little should inch off.
Lo-Fi Version | Time is now: November 30th, 2024 - 8:34 PM |
