HID Kit Install 56K BEWARE!!, HID's from culpable |
Oct 20, 2006 - 11:29 AM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
QUOTE(LewFX @ Oct 20, 2006 - 11:05 AM) [snapback]494103[/snapback] i got them in, but what do the extra 2 cords with metal poking out go? They go to one of your H1 connectors, or you can cut and splice it to the stock headlight wiring harness. That's where the signal for the relay comes from, and then goes to the ballast. . -------------------- |
wheres this go?
Oct 20, 2006 - 1:29 PM |
Enthusiast Joined Nov 22, '05 From Mesquite, Texas Currently Offline Reputation: 0 (50%) |
Those two wires were not included in my 9006 Kit. Do your lights work without them being pluged in to anything?
Oct 20, 2006 - 1:49 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
Those plug into your original H1 socket (Red +, Black -).
Nov 4, 2006 - 8:04 PM |
Enthusiast Joined Jan 6, '06 From Oahu, Hawaii Currently Offline Reputation: 0 (0%) |
I have a quick question. . . can you wire the HIDs to the stock headlight harness and not use the resistance wire and HID harness the battery connector? please PM me ASAP.
Nov 4, 2006 - 9:05 PM |
ill say no
Nov 5, 2006 - 4:12 AM |
it actually works pretty well, any one else have comments?
Yet |
Jan 10, 2007 - 5:26 PM |
Enthusiast Joined Jul 9, '04 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
lol, i about to get me some projectors, and a HID kit, yet the pictures are not there anymore!!!
any chance of re-uploading them? |
Feb 19, 2007 - 5:24 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
bump, pics anyone?
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Feb 19, 2007 - 5:25 PM |
QUOTE(jason @ Feb 19, 2007 - 5:24 PM) [snapback]528431[/snapback] bump, pics anyone? What pictures do you need? I can retake some for you. |
Feb 19, 2007 - 5:34 PM |
Enthusiast Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
I need pics of the install or something with Projectors. I installed mine but theyre not working. I dont know what to do
Feb 20, 2007 - 10:30 AM |
heres another write up & comparing against another car, i posted some small gif images i think like 80k ttl for all of them
http://www.6gc.net/forums/index.php?showtopic=45554 QUOTE I need pics of the install or something with Projectors. I installed mine but theyre not working. I dont know what to do whats happening? dont light up at all? blinking? -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
Feb 22, 2007 - 8:05 AM |
well I got them working(blew a fuse installing them), but now my drivers side wont turn on at all. I checked all my wiring, the fuses, and all of the connections to make sure everything was still in order and everything was good. This is where I get lost. The only thing I havent done is check the bulb to find out if maybe it got broken or is blown already.
Feb 23, 2007 - 2:08 PM |
so I started my car today just to watch the passenger side one start to blink then it quit on me too. Could someone please help me with this.
Feb 23, 2007 - 3:02 PM |
QUOTE(massbrandon @ Feb 22, 2007 - 8:05 AM) [snapback]529309[/snapback] well I got them working(blew a fuse installing them), but now my drivers side wont turn on at all. I checked all my wiring, the fuses, and all of the connections to make sure everything was still in order and everything was good. This is where I get lost. The only thing I havent done is check the bulb to find out if maybe it got broken or is blown already. QUOTE(massbrandon @ Feb 23, 2007 - 2:08 PM) [snapback]529692[/snapback] so I started my car today just to watch the passenger side one start to blink then it quit on me too. Could someone please help me with this. These bulbs are VERY sensitive to any touch or movement. If you have messed with them in ANY way it could result in malfunction. Maybe the bulb, or ballast, are bad. Both can result in your light not working properly. Where did you get your kit from? |
Feb 23, 2007 - 5:10 PM |
I got the kit from the GB that culpable ran. So in other words I got the same ones that everyone else has.
Feb 23, 2007 - 5:27 PM |
ballast....
mishandling in shippin can poss cause that so im told, my one did that, not using them right now so i dont know how the other one is holding up, but it was working perfectly when i had it in ... the blinking when you first turn them on at idle - you can just rev it to give it some mroe juice and it should stop the blinking also blinking is not good for hid bulbs, and if you touched them or got anytype of moisture or oilyness on them it may cause the bulb to overheat and blow.. if the bulbs are clear and no cracks then id think it was the ballast - try reading up on the system on wikki if ya have nothing better to do if for nothing else gives you an idea of what all is goin on up there in them headlights -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
Feb 23, 2007 - 10:23 PM |
Enthusiast Joined Feb 3, '05 From Tampa, Florida Currently Offline Reputation: 2 (100%) |
massbrandon: I had the same problem also bro. Both my ballast working fine....then after driving it, the passanger side quit working. I blew about 3 "15" fuses. SO now i have to get a new ballast. On a side note, i checked the bulb and it works fine so i know its the ballast that is malfunctioned.
-------------------- I'am Reinventing the SLow Lane.....
Mar 28, 2007 - 1:02 PM |
Enthusiast Joined Jul 4, '06 From winnipeg Currently Offline Reputation: 2 (100%) |
i keep blowing the 15a fuse for the headlights...
ive read on the net to put 20a in....i dont know why they keep blowing |
May 3, 2007 - 8:16 PM |
Enthusiast Joined May 3, '07 Currently Offline Reputation: 0 (0%) |
hey sorry to bump this old post, but it is the only, step by step hid install for the 6th gen I can find and the pictures arnt working for me. Would it be possible to rehost them? thanks very much.
or also a link to a install of a kit on another 6th gen would be awesome as well. |
Lo-Fi Version | Time is now: November 30th, 2024 - 7:46 AM |
