Enthusiast ![]() ![]() ![]() Joined May 5, '05 From mattoon, IL Currently Offline Reputation: 2 (100%) ![]() |
ok, my car was just recently turbo'd, and today i took it out and there is white smoke coming off the manifold, it almost looks like its leaking out of the manifold,,,, also when i let off the pedal from heavy acceleration a big puff of white smoke pours out the exauhst what would be causing this???
Enthusiast ![]() ![]() Joined Aug 21, '06 From washington Currently Offline Reputation: 4 (100%) ![]() |
head gasket is leaking coolant into the cylinders.
how do i fix that?
i'v been out driving it around more now and the smoke its starting to clear up, almost no smoke now? i think it could just have been burning off excess oil, cause we had a big oil leak the other day. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) ![]() |
It sounds like coolant to me too. A big oil leak would not result in smoke coming out the exhuast, it would just burn off and smoke in the engine bay. If it is a headgasket leak, then the way you would fix it is to get a new headgasket and have some fun
run a compression check and leakdown test.
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(nate95 @ Oct 21, 2006 - 2:54 PM) [snapback]494520[/snapback] how do i fix that? i'v been out driving it around more now and the smoke its starting to clear up, almost no smoke now? i think it could just have been burning off excess oil, cause we had a big oil leak the other day. did you wash your engine after the oil leak , that could be it ![]() ![]() This post has been edited by trd94: Oct 21, 2006 - 3:25 PM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) ![]() |
Could be oil in your exhaust from your turbo, burning oil in your exhaust is white.
yea, did you put an oil pressure restrictor in the feed line?
um no i had to drive it back home from johns without a restrictor, cause the restrictor i had, broke off so we just used a normal brass fitting, so im pretty sure it was puing oil into the exauhst
you can make your own restrictor. just fill a brass fitting with solder then drilll a hole though thats smaller.
what the heck are you using for an oil feed line that keeps coming off? -------------------- |
with my luck the solder would just pop out and into the turbo
use a fitting with a lip in it, and clean the brass with acid flux so the solder bonds to it.
how come the oil feed keeps coming loose? can you get some pics of whats happening? -------------------- |
i got the oil problem fixed but now my radiator is punctured
QUOTE(nate95 @ Oct 21, 2006 - 11:17 PM) [snapback]494634[/snapback] i got the oil problem fixed but now my radiator is punctured ![]() that happend to me also but mine was the turbo housing popped in to it after a real hard launch and the motor flexed a little more than i figured , new motor mounts and a new desinged manifold works now and i dont have anything within 3/4 of a inch to the radiator ![]() ![]() -------------------- ![]() |
i just patched that beast up reall good, shes not leakin anymore
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:53 PM |
