> Build pics
post Oct 21, 2006 - 11:20 PM
Punisher
Joined Jun 19, '06
From Portland, OR
It's about 98% done I'd say... The list of things to finish
Intercooler mounting brackets
Washer resevior mounting
Put hood/bumper on
Exhaust system (3" straight back under axle with Flowmaster 40series 3" in w/ 2 2 1/2" outlets)
Anyway it's been a long long road.. mainly because of problems that popped up during the build and after...
List of mods/work (I'll start at bottom of motor and work up)
Completely rebuilt 3SGTE -
All engine seals
Main bearings
Rod Bearings
ARP Rod bolts
ARP Head studs
Cometic Metal HG
New valve stem seals
Head cleaned and valve shims adjusted
New piston rings
New water pump and pulleys & tbelt tensioner
Transmission -
99 Camry V6 5spd trans w/ 40K
95 JDM MR2 LSD
Stage 3 clutch w/ 11lb Chromoly Fly
Exhaust -
Custom 3" downpipe (Made for CT26, customized to fit the GT28)
S/S tubular header w/ custom adapter plate to go from CT26 flange to GT28
GT28R Turbo
38mm external gate
3" Straight back pipe w/ Flowmaster 40 muffler (no cats/res)
Intake -
Completely cleaned and sandblasted Manifold, throttle body
Intercooler (3 3/4" thick by 20" across and 13" bottom to top .. thereabouts)
2 1/2" aluminum IC pipe
Forge Motorsport Diverter valve (recirc. valve)
Bored Fuel Rail (Like ATS.. except I did it)
Custom throttle body inlet adapter (like the one ATS Makes.. except I made it..)
Electronics -
Apexi AVC-R Boost controller
AEM Wideband O2 gauge
GlowShift (eBay...) Tint gauges .. black faces when power is off.. they look nice .. see how well they work.
I think that's about it... I made a LOT of custom things for this engine either by myself or with the help of some friends.. So I'm pretty damn happy with it all.
I did the wiring myself and yes.. everything worked the first time around. The last 2 wiring harness jobs I did were more difficult than this one.
I hope everyone likes the pics and what you see.. I can't wait to take it on the road. I'm hoping to do so tomorrow but we shall see. I'm not in the mood to rush anything at this point since it is so close to being done. I want to make sure it's 100% before I let my hard work tear up the asphalt.
http://tekphobia.com/Alltrac/94sideview.JPG
http://tekphobia.com/Alltrac/94sideview2.JPG
http://tekphobia.com/Alltrac/94sideview3.JPG
http://tekphobia.com/Alltrac/94interior.JPG
http://tekphobia.com/Alltrac/94interior2.JPG
http://tekphobia.com/Alltrac/94interior3.JPG
http://tekphobia.com/Alltrac/94interior4.JPG
http://tekphobia.com/Alltrac/94interior5.JPG
http://tekphobia.com/Alltrac/94interior6.JPG
http://tekphobia.com/Alltrac/94interior7.JPG
http://tekphobia.com/Alltrac/94interior8.JPG
http://tekphobia.com/Alltrac/94front.JPG
http://tekphobia.com/Alltrac/94front2.JPG
http://tekphobia.com/Alltrac/boostcontroller.JPG
http://tekphobia.com/Alltrac/94turbo.JPG
This post has been edited by Punisher: Oct 21, 2006 - 11:21 PM
87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
post Oct 21, 2006 - 11:22 PM
burnyd
Joined Oct 13, '06
From Pittsburgh
awesome......
post Oct 22, 2006 - 12:58 PM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
Very nice!
Converted JDM '98 GT-Four to LHD, check my site: Celica GT.nl
post Oct 22, 2006 - 1:27 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
sweet man!
post Oct 22, 2006 - 2:18 PM
Cavanagh
Joined Mar 21, '06
From Springfield, IL
Damn punisher, its lookin good! Your Engine/Engine bay looks nice and clean.
post Oct 22, 2006 - 2:36 PM
trd94
Joined Jan 9, '05
From green springs ohio
awesome work man!!
post Oct 22, 2006 - 2:45 PM
Punisher
Joined Jun 19, '06
From Portland, OR
Thanks.. I spent a lot of time working on this thing..
post Oct 22, 2006 - 3:27 PM
shin
Joined Aug 21, '04
From New York City
looks awesome. the turbular manifold is sweet
~*MuH NeW RiDe*~
post Oct 22, 2006 - 10:53 PM
hitcachi
Joined Jun 19, '05
From Nebraska
Damn, its looking really good. That is a huge intercooler. And A+ on going with the heat wrapping right away. Also, what brand clutch did you go with for the stage 3? GT28R ftw!
post Oct 22, 2006 - 11:48 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
hey im pretty sure your wastegate is backwards. maybe its just me. but normally isee them the other way.
actaully im 99% positive its wrong. better fix that before BOOM.
thats normally how its supposed to be hooked up.
This post has been edited by x_itchy_b_x: Oct 23, 2006 - 12:38 AM
post Oct 23, 2006 - 11:37 AM
Punisher
Joined Jun 19, '06
From Portland, OR
Itchy, I see what you mean... Nothing will go boom though.. the valve will still open.. I'll see what the possible side affects are though and if need be I'll switch it around.. I can't believe I didn't notice that
post Oct 29, 2006 - 9:42 PM
Punisher
Joined Jun 19, '06
From Portland, OR
Update..
I've been driving her around for the past couple of days and I LOVE IT.. the thing is insanely fast.. and I've only been pushing around 4-6PSI tops and barely running the gears.. and it just out right hauls ass...
The E153 is amazing.. I was doing 80mph down the highway in 5th at 3K rpm... all the gears are super long..
The turbo will spool up anywhere between 2-3K RPM depending on the gear and load on the engine.. if I am going up hill and my RPMs are low.. like 2-2500... Give it some gas and the turbo is happily boosting instantly..
I have the TVIS actuactor hooked up to the intake manifold so once i come out of vacuum the plates open.. that is workin out fantasticly.
When I start to get up to 4-5PSI the wideband reads rich off the gauge.. so less than 12:1 I believe that is.. either 12:1 or 11:1... so my fuel is perfect.. I should be able to push 15-16PSI safely fuel wise... I don't even think I want to feel that thing at 15-16PSI.. I'll probably lose a lung.
I think my boost stuttering issues are due to a misadjusted TPS.. so tomorrow I will look it up in the BGB and adjust it properly and see if that fixes it.. I tried to roll the ign. timing back and that didn't change anything..
I need to make those knock sensor LEDs up to be on the safe side as well.
Anyway guys.. I'm very very happy with my swap and the turbo I went with along with everything else... It was definitly worth the time and effort 100%.
post Oct 29, 2006 - 10:13 PM
celica47
Joined Feb 3, '05
From Tampa, Florida
How much did you pay for the LSD? And do you think its worth it?
I'am Reinventing the SLow Lane.....
post Oct 29, 2006 - 10:30 PM
Punisher
Joined Jun 19, '06
From Portland, OR
Paid 400 total shipped from japan... it's from a 95 MR2.
The LSD is TOTALLY worth it man.. I get no torque steer.. and the other day the roads were wet and I came into boost and started to spin the tires.. I can't imagine how bad it would be with out the LSD.. spin tire... go into torque steer.. crash and die.
I don't feel like fighting torque steer on a car that will be putting down serious HP numbers.. plus it's going to be a daily driver.. When I'm out in the snow and slush that LSD will be a bloody life saver.
post Nov 2, 2006 - 10:40 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
awesome work. thumbs up for a local!
post Nov 2, 2006 - 10:42 AM
celica47
Joined Feb 3, '05
From Tampa, Florida
wow....WHERE did you did a LSD tranny for that much? Pm me for your secret lol....
post Nov 2, 2006 - 11:14 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
No, that was just his LSD that he got for 400 dollars, he used a 99 Camry E153 transmission then installed an LSD into that trans.
I worked with Steve on this project and so I have a little insight into what he did and its pretty friggin cool. thumbsup.gif Very clean rebuild, this whole motor is totally spotless, its not just a pretty valve cover. I should find a picture of the motor on the engine stand...
post Nov 2, 2006 - 11:37 AM
Punisher
Joined Jun 19, '06
From Portland, OR
QUOTE(Silver94CelicaOwner @ Nov 2, 2006 - 11:14 AM) [snapback]498692[/snapback]
Thanks Man... Cory did help out a lot with this.. I appreciate the extra hands.
The exhaust is in the process of being installed.. it's a 3" over axle smile.gif.. Yes.. OVER axle
Lo-Fi Version Time is now: November 23rd, 2024 - 2:48 PM
