![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) ![]() |
Does anybody have information on the torque specs for the various nuts and bolts in the struts for s 94 ST? Gonna be changing the springs and i would perfer not to guesstimate the torque.
This post has been edited by Daftboy: Oct 23, 2006 - 2:44 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
Well did the fronts..not sure of the specs but oh well...it got to late to do the rears...so that will be tommorw's task.
![]() Enthusiast ![]() ![]() Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) ![]() |
fairly tight
![]() bigal This post has been edited by bigal004321: Oct 23, 2006 - 5:29 PM -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Enthusiast ![]() ![]() Joined Apr 29, '03 From lynn,ma Currently Offline Reputation: 0 (0%) ![]() |
front:
TORQUE SPECIFICATIONS TABLE Application Ft. Lbs. (N.m) Axle Nut ....................................... 166 (226) Axle Shaft Flange Bolts (All-Trac) ............... 48 (65) Ball Joint-To-Lower Control Arm Nut ............. 94 (127) Ball Joint-To-Steering Knuckle Nut .............. 76 (103) Brake Caliper-To-Knuckle Bolt ................... 79 (107) Brake Hose-To-Caliper Bolt ....................... 22 (30) Crossmember Bolts/Nuts ......................... 112 (152) Drive Shaft Flange Bolts ......................... 54 (74) Exhaust Pipe Hanger Bolts ........................ 14 (19) Lower Control Arm Bracket-To-Body Bolt ........... 72 (98) Lower Control Arm Nut Front ......................................... 156 (211) Rear .......................................... 101 (137) Lower Control Arm Shaft-To-Body Bolt ........... 112 (152) Stabilizer Bar Link Bolt ......................... 26 (35) Stabilizer Bracket-To-Body Bolt .................. 13 (18) Steering Knuckle-To-Strut Bolt ................. 224 (301) Strut Assembly-To-Body Nuts ...................... 59 (80) Strut Assembly Top Support Nut ................... 34 (47) Tie Rod-To-Knuckle Nut ........................... 36 (49) Wheel Lug Nuts .................................. 76 (103) rear TORQUE SPECIFICATIONS TORQUE SPECIFICATIONS TABLE Application Ft. Lbs. (N.m) Axle Hub-To-Axle Carrier Bolt .................... 59 (80) Axle Shaft Nut .................................. 90 (122) Stabilizer Bar Link Nut .......................... 47 (64) Stabilizer Bar Mount Bolt ........................ 14 (19) Strut Rod Bolt .................................. 83 (113) Strut-To-Axle Carrier Bolt ..................... 188 (255) Strut-To-Body Nut ................................ 29 (39) Suspension Arm-To-Axle Carrier Bolt ............ 134 (182) Suspension Arm-To-Body Bolt No. 1 (Front) Arm ............................. 83 (113) No. 2 (Rear) Arm ............................... 64 (87) Suspension Arm-To-Body Nut (No. 2 (Rear) Arm ... 166 (226) Wheel Lug Nut ................................... 76 (103) INCH Lbs. (N.m) Speed Sensor Bolt ............................... 69 (7.8) got it from the manual thingy at celicasomething.com or something i forgot |
Enthusiast Joined Apr 17, '06 From Peoria, Az Currently Offline Reputation: 0 (0%) ![]() |
Its too nice...I wouldn't trust it!! LOL.
Just keep crankn it until your head starts hurting. This post has been edited by veritas: Nov 20, 2006 - 7:00 PM -------------------- Nick
-95 st -05 xterra -07 ms3 |
Lo-Fi Version | Time is now: April 23rd, 2025 - 5:47 PM |
