> Rod Bearings, keep going bad
post Oct 24, 2006 - 3:26 PM
bobw
Joined Mar 30, '05
From Schuylkill County, PA
I was just wondering if anyone else has had a problem with 5sfe rod bearings going bad mad.gif , and if so what have you done to fix the problem. Any help will be greatly appreciated
Thanks
-Eric
post Oct 24, 2006 - 9:01 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
QUOTE(bobw @ Oct 24, 2006 - 3:26 PM) [snapback]495576[/snapback]
Thanks
-Eric
Your only Solution is to dismantle your engine and buy new rod bearings, perhaps get stronger ones and ARP rod bolts. Do regular oil changes, never abuse the engine when its still cold and that should help out a lot. Most Rod bearings brake because its not receiving enough oil and friction creams it pieces.
A SWAP will just cost you more and giv emore headaches. Nows a good time to replace seals and do an engine rebuild.
post Oct 24, 2006 - 11:57 PM
bobw
Joined Mar 30, '05
Thanks alot, i was thinking of just building the spare 5sfe over the winter and puttin a 3sgte head on and a turbo, and fixing the one thats in there with an oversize bearing to see if that help is for she's sitting for the winter
This post has been edited by bobw: Oct 25, 2006 - 12:03 AM
Lo-Fi Version Time is now: April 21st, 2025 - 7:20 PM
