If stock amp(s) go out...., a dumb question I know |
Oct 25, 2006 - 4:28 PM |
Enthusiast Joined Mar 6, '05 From Fort Worth, TX Currently Offline Reputation: 0 (0%) |
I have the two stock amp setup (Premium Sound setup). If one or both amps stock amps go out, will I not hear anything coming from the speakers controlled by that particular amp? Second question is: If one of the amps is "starting to go out" (not sure if this is possible) what would the symtomps be?
I'm pretty sure I know the answers, and yes the second Q seems pretty dumb..... Im just kinda bored and I have not posted in a while. And no I'm not having problems with my amps but I did however buy a second "under the front seat" amp ($7 so I figured what the hey) and I was wondering if I would notice a difference if I tried this second one. Meaning maybe this one is in better shape than my current one. Im just to lazy to try. -Vic This post has been edited by UTSlickVic: Oct 25, 2006 - 4:30 PM -------------------- |
Oct 25, 2006 - 10:18 PM |
i guess it all depends on how your headunit is wired up.. if it was wired up without the amp integration harness, then your probably not using the amplifiers in the first place. rather, your speakers are powered by the built-in amp of the headunit.
Oct 26, 2006 - 11:46 AM |
QUOTE(azian_advanced @ Oct 25, 2006 - 10:18 PM) [snapback]496163[/snapback] i guess it all depends on how your headunit is wired up.. if it was wired up without the amp integration harness, then your probably not using the amplifiers in the first place. rather, your speakers are powered by the built-in amp of the headunit. Yeah its wired up using the OEM amp harness/harness going to the head unit.... I ddi not bypass the amps if thats what ur hinting at. ASIDE: But you bring up an interesting point. If I unplug one of the amps, I wonder what will happen. I guess if no sound comes out of the speakers then I guess I did my wiring correctly. But I digress. anyone else have input to my original post? This post has been edited by UTSlickVic: Oct 26, 2006 - 11:46 AM -------------------- |
Oct 26, 2006 - 3:19 PM |
Enthusiast Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) |
hmm actually i think if you unplug one, all of the speakers will still work, because power is given to them from the HU... but some will be louder than others because of the lack of power from the amp... just a guess though, never really messed too much with the component speakers
Oct 26, 2006 - 3:36 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
One amp powers the standard 6 speaker system, and the other amp is added to power the extra 2 speakers in the "Premium Sound Setup". So depending on which amp you unplug (or goes out) you wont hear any sound from the speakers powered by that amp.
EDIT: Oh yeah, also keep in mind that the radio gets it power from the stock main amp connection. Unplug it and the radio wont even turn on. This post has been edited by MaskedMan: Oct 26, 2006 - 3:38 PM -------------------- |
Oct 26, 2006 - 5:18 PM |
For example, if you just use the regular toyota harness, it disconnects you from the amp under your chair and you won't hear anything. I think what you are saying is no amp=low power, but really it is no amp=no sound.
Oct 27, 2006 - 4:57 PM |
QUOTE(MaskedMan @ Oct 26, 2006 - 3:36 PM) [snapback]496439[/snapback] One amp powers the standard 6 speaker system, and the other amp is added to power the extra 2 speakers in the "Premium Sound Setup". So depending on which amp you unplug (or goes out) you wont hear any sound from the speakers powered by that amp. EDIT: Oh yeah, also keep in mind that the radio gets it power from the stock main amp connection. Unplug it and the radio wont even turn on. Umm I thought the which amp controls what is a little bit funckier than that (for the Premium Sound System)...anyways yeah I agree what you said. Good points. Thanks. QUOTE(trdproven @ Oct 26, 2006 - 5:18 PM) [snapback]496476[/snapback] For example, if you just use the regular toyota harness, it disconnects you from the amp under your chair and you won't hear anything. I think what you are saying is no amp=low power, but really it is no amp=no sound. You almost hit the nail on the head, regarding my questions. What I was speculating was, (Low speaker sound = Almost bad amp), but really it should be (Almost bad amp = Bad Amp = No Speaker Sound)... I guess there is no such thing as an amp starting to go bad? If so, the signs would be pretty apparent, not subtle. Right? -------------------- |
Lo-Fi Version | Time is now: November 27th, 2024 - 12:43 PM |
