Autocross: I got madd questions for you guys!, Info needed for the crowd that autocrosses |
Nov 10, 2006 - 1:05 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
i should be more specific. my fault.
Nov 22, 2006 - 12:21 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
225/45/16s are what Iam running on in my last event.. and whoa! my rear hates me.. it kicks out hard when I let off the acc. and when I take a sweeper.. halfway on a left or right sweeper it looses traction in the rear..
Remedy for this kick out? |
Nov 22, 2006 - 8:12 PM |
i'm thinking: adjust rear sway bar, if it is adjustable that is.
Nov 22, 2006 - 9:52 PM |
nothing is adjustable except for my tire pressure. =[
I was planning on getting some tires once more on my 15s but.. 300 for a set uhh.. i dont make good money at my work.. lol I had an idea.. might sound dumb as fcuk but o well.. Front: 225/45/16 ES100 Rear: 205/50/15 Ecsta SPT they are the same height.. I would have less chances of getting loose because their not as wide in the rear. I would however get more rotation in the rear during tight turns |
Nov 22, 2006 - 10:07 PM |
QUOTE(jdg371 @ Nov 22, 2006 - 9:52 PM) [snapback]504653[/snapback] nothing is adjustable except for my tire pressure. =[ I was planning on getting some tires once more on my 15s but.. 300 for a set uhh.. i dont make good money at my work.. lol I had an idea.. might sound dumb as fcuk but o well.. Front: 225/45/16 ES100 Rear: 205/50/15 Ecsta SPT they are the same height.. I would have less chances of getting loose because their not as wide in the rear. I would however get more rotation in the rear during tight turns |
Nov 22, 2006 - 11:51 PM |
Enthusiast Joined Nov 23, '05 From Charleston, WV Currently Offline Reputation: 1 (100%) |
I'm running my ST in our SWVR and won a STS for a season. Nate with his GT just started, so I trying to help him as much as I can, but he did great for a first time. I was impressed.
Anyway... I'm using Dropzone lovering springs 1.5" drop with a OEM shocks. Super set up for a start. Also using GT sway bars. ( helped a lot) Camber front: -2.6, rear -1.0 Best what you can do for no many spended. Next season buying adjustable shock. That is going to help a lot, because my current ones are shot pretty bad. So buy some Dropzones or whatever with max 1.5" drop, if you want to stick with stock shocks and just learn the car. After you know your car , you can start spend more many in to it. That way you buing something what is going to actually help you. Lots off people spending many for all kind off sway bars, strut bars , coilovers etc with out any sense or knowledge. So that's what I think and you can take it or not. Good luck with your car and have fun with it. Web side: swvrscca.org http://s66.photobucket.com/albums/h246/mir...autoxcelica.jpg This post has been edited by miro1975: Nov 23, 2006 - 12:04 AM |
Nov 22, 2006 - 11:56 PM |
Falken Azenis. Best tire for autocross 200 tw , A A
Great tire. |
Nov 23, 2006 - 11:26 AM |
Im staying stock for a while. I might get some camber in the F/R for the winter season.. but thats about it..
heres a pic of my car taking a turn. I think I lifted the rear tire lol.. can you say stupid ammount of bodyroll? |
Nov 23, 2006 - 11:56 AM |
Some body roll is actually good for autocross. Gives you better grip at tite corners. But - camber gonna help you a lot. Get your self a set of camber bolts at you all set. You can do up to -2.7, I think. Car looks good on course...
Nov 26, 2006 - 12:24 AM |
QUOTE(jdg371 @ Nov 23, 2006 - 2:52 AM) [snapback]504653[/snapback] nothing is adjustable except for my tire pressure. =[ I was planning on getting some tires once more on my 15s but.. 300 for a set uhh.. i dont make good money at my work.. lol I had an idea.. might sound dumb as fcuk but o well.. Front: 225/45/16 ES100 Rear: 205/50/15 Ecsta SPT they are the same height.. I would have less chances of getting loose because their not as wide in the rear. I would however get more rotation in the rear during tight turns I used to run something similar to that. If I remember correctly... Fronts were 215/45/16 Rears were 195/50/16 -------------------- "It's ok to be naked girl... I'm an artist!"
Nov 30, 2006 - 1:50 PM |
Honestly for FWD cars, If you increase the spring height in the front and lower the back you get better turning vs lower the front and raise the back. Plus if you run stock tires it actually performs better than aftermarket tuner tires. One plus side if you can't raise the height is to let out some pressure from the back tires and increase the pressure in the front. Adding extra weight to the front actually makes it easier to control cornering when your sliding. Remember your not on an offical track and your just on a parking lot. A parking lot actually slides easier than real roads. What you can do in real life does not count on a lot. So no fancy moves will actually work.........such as hugging a guard rail.
Dec 1, 2006 - 10:43 AM |
QUOTE(soulshadow @ Nov 30, 2006 - 1:50 PM) [snapback]506632[/snapback] Honestly for FWD cars, If you increase the spring height in the front and lower the back you get better turning vs lower the front and raise the back. Plus if you run stock tires it actually performs better than aftermarket tuner tires. One plus side if you can't raise the height is to let out some pressure from the back tires and increase the pressure in the front. Adding extra weight to the front actually makes it easier to control cornering when your sliding. Remember your not on an offical track and your just on a parking lot. A parking lot actually slides easier than real roads. What you can do in real life does not count on a lot. So no fancy moves will actually work.........such as hugging a guard rail. You should never raise the car for autocross. Lower is better. Sometimes you can run less psi in the rear to keep it a little loose. Adding weight to the front isn't a good idea. You get all the weight up there you need when you break, especially in a Celica. I've never seen a FWD car that needed wieght up front. Some could use it in the back to keep them from "flopping" about and loosing the back end though. I don't understand by what you mean by no fancy tricks. You have to hit the best line, and you have to use the cars body role to control it. What other tricks are there? 360s? Not all autocross is on parking lots. And even if I was, different lots have different levels of traction. -------------------- Live Free, Be Happy
Dec 4, 2006 - 3:03 AM |
QUOTE(Bigmeanbulldog55 @ Dec 1, 2006 - 7:43 AM) [snapback]506898[/snapback] You should never raise the car for autocross. Lower is better. Sometimes you can run less psi in the rear to keep it a little loose. Adding weight to the front isn't a good idea. You get all the weight up there you need when you break, especially in a Celica. I've never seen a FWD car that needed wieght up front. Some could use it in the back to keep them from "flopping" about and loosing the back end though. I don't understand by what you mean by no fancy tricks. You have to hit the best line, and you have to use the cars body role to control it. What other tricks are there? 360s? Not all autocross is on parking lots. And even if I was, different lots have different levels of traction. i disagree with your logic. I'm into RC car suspention tuning and this is where i base my suspention knowledge. Since this is a front wheel drive car, it will experience understeer. Decreaseing rear tire pressure will increase contact patch therefore increasing grip. Increase rear grip will make the car understeer even more. I do know inorder to drive a fwd car fast around the track, you can brake hard and shift the weight to the front causings the rear of the car to have less grip. This will essentially cause the rear to slide out allowing you to make tighter turns and decreasing understeer. |
Dec 4, 2006 - 5:26 PM |
Hanyo, I see why your saying what your saying. It's something that I've heard a long time ago and have used and seen other racers use, but never seen actual reference for it.
HERE for Reference -------------------- Live Free, Be Happy
Dec 28, 2006 - 10:17 PM |
Enthusiast Joined Jun 3, '06 From Glasgow, VA Currently Offline Reputation: 0 (0%) |
Back in the day the stripped ST coupes were the autocross cars to have. They were actually faster then the GT's. The ST's are lighter, have little to know wheel spin issues (at least my R-compound experience) and have more low end torque then the GT's. I believe that the GT's also fall off of their powerband on the 1 -2 shift.
When the back end of your car rotates be sure to keep your foot in the throttle, to pull it out. I run mine with the back quite loose, either by stiffening the rebound on the shocks, ie tap brake car rotates, or by running 205 tires in the rear. I currently live in the Milwaukee area, where Jeff Cashmore resides, multiple time national champ, who stills has one of the celicas he used to autocross. For stock Jeff tried all sorts of different front bars and came back to stock bar as being the best. Locally you may make one into a competitve STS car, but nationally I do not think it will happen. The car even though quite light will always be at a weight disadvantage, and is down on power even compared to the lower powered STS cars (wait a minute they are all low powered!!). The suspension can only be lowered a so much or the geometry will be out of whack and mess up the handling. For any of them get the full negative camber in the front, and you should be able to yank about 1 degree in the rear. I run with about 1/8" toe out in the front and 0 toe in the rear. A good alingment is the best bang for the buck. I really like they car, just whish they would have moved it to H-stock like they had proposed. Dan |
Mar 11, 2007 - 8:33 PM |
Prep since I have money again. Getting an alignment [finally!]
I have two 2dot and two 3dot camber bolts.. are the rears adjustable? I haven't messed around with alignment and not sure if its possible to put camber bolts in the rear. If it is.. I will put the 3dots in front and 2dots in the rear. from what ive read.. 1degree front and 1.5degree rear is ideal? I will be running on some.. Azenis 215s [older version] |
Mar 12, 2007 - 8:43 PM |
Put the smallest bolts you have in the front should be able to get about 2.5 degrees negative camber.
The rear is adjustable, though I have not messed with it, stock you should be able to get about 1 degree of negative camber. I would also go with zero toe in the rear and about 1/8" total toe out in the front. (these are based on a stock class car) And yes you will wear your tires at an angle. Dan Forgot something else. The old hot stock autocross set-up used to be running GT struts in the front and Convertible struts in the rear. Possibly a lower cost alternative then adjustables. Dan |
Mar 12, 2007 - 8:55 PM |
Thanks. How bad of tire wear would that setup add?
I'll use those alignment specs and get it aligned hopefully Wednesday or Thurday. This post has been edited by jdg371: Mar 12, 2007 - 8:56 PM |
Mar 13, 2007 - 10:32 PM |
I'm going to run about 1.7-1.8 up front and 1.5 in the rear. Miro (STS Region Champ) runs 2.0 in front and 1.5 in the rear. I think that's right, he might come on here and correct me.
Mar 13, 2007 - 10:52 PM |
Enthusiast Joined Jul 29, '03 From north of detroit Currently Offline Reputation: 6 (100%) |
i'm going to shoot for -2.5 front, -2.0 and zero toe on the rear.
i am still debating between falken 615s and the hankook 512. i have used the 615s in the past and been very happy, but i've been hearing alot of good things about the hankooks lately. i'm stoked, i have a set of ss dampers waiting to be installed. it's going to take some time to get everything dialed in, but it'll be awesome when it's set. -------------------- do you know who i am, mr. worley? |
Lo-Fi Version | Time is now: November 29th, 2024 - 3:38 AM |
