> SEA FOAM BABY!!, WARNING: 56K SCHMOKINNNN!!!
post Oct 26, 2006 - 10:17 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
IPB ImageIPB Image
these are pics of what happens when you suck in the seafoam thru your pcv valve! more smoke=more cleaning action! (you can also use one of your vaccum lines but youre better off using the pcv.
also use in gas tank and oil crank case (BEFORE AN OIL CHANGE)
ive been meaning to get these pics on here since june! I remember someone saying they couldnt get their pics up a long time ago
once you use it you can feel the difference! it continued to smoke real bad after i drove home but it went away...
This post has been edited by easternpiro1: Oct 26, 2006 - 10:26 PM
post Oct 26, 2006 - 11:33 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
is sea foam good to use or bad, ive heard mixed results
post Oct 26, 2006 - 11:37 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
actually.. i was trying 2 do that 2day and put it thro a vacuum line.. but yea... i bought a hose that didn't fit =/
and actually.. i heard through a vacuum line was better than pcv
06 Civic EX
My For Sale Thread
post Oct 27, 2006 - 12:08 AM
pure_dx
Joined Dec 28, '05
From USA
QUOTE(LewFX @ Oct 26, 2006 - 11:33 PM) [snapback]496649[/snapback]
i heard the same as you
post Oct 27, 2006 - 12:26 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
I used seafoam, but mine did not smoke that much haha. I used the brake booster hose. But it worked really well for my car, i really like the stuff smile.gif.
post Oct 27, 2006 - 1:23 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
It works the same as your synthetic oils. It cleans everything out really well. That is usually considered a good thing. But the problem is, there could be chucks of stuff that get knocked loose and then cause problems. Like a big chuck of carbon. I don't know if it collects like that, but that's what I've heard against sea foam. My car has 155k on it, and I use sea foam. Never hurt anything. You always run the risk of stuff like that when you dump things besides gas in your motor. Just be ready for it. The sea foam in the gas tank really helps. You notice a difference in the pick up of the car with it in there. Once it's gone, so is the extra oomph. I use a Lucus oil fuel system cleaner with every tank of gas I put in. Lubricates valves and helps the gas burn hotter. And that's a good thing. More effectant burn. Basicly, us all at your own risk, but I would try it.
Live Free, Be Happy
post Oct 27, 2006 - 3:20 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
heres the other post you were probably talking about...
http://www.6gc.net/forums/index.php?showtopic=22522&hl
there are a few other threads about seafoam but that one has more responses.
I <3 Dustin---07/16/06
post Oct 27, 2006 - 7:19 AM
vozizm
Joined Sep 18, '06
From North Carolina
used it in my expedition, used the brake vacuum line.. works like a champ!!!
VOZ™
post Oct 27, 2006 - 9:17 AM
Jaws4God
Joined Mar 27, '04
Matt.. I remember when you first used it at the Advance Auto meet.. LOL we got pics of you using a soda can to inject it.. LOL
post Oct 28, 2006 - 12:33 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(hurley97 @ Oct 27, 2006 - 3:20 AM) [snapback]496707[/snapback]
YUP thats the one! (wow i cant believe i had 185k on my car then biggrin.gif its at like 230k now!
QUOTE(Jaws4God @ Oct 27, 2006 - 9:17 AM) [snapback]496753[/snapback]
btw...ive been considering putting it into my 3s... it says its okay on turbo applications but once again im nervous....
This post has been edited by easternpiro1: Oct 28, 2006 - 12:34 AM
post Oct 28, 2006 - 10:59 AM
so how are you enjoying your new turbo celica? i didnt really see you post a review or anything yet.
post Oct 28, 2006 - 11:23 AM
shin
Joined Aug 21, '04
From New York City
~*MuH NeW RiDe*~
post Oct 29, 2006 - 12:30 AM
elvasoshexai
Joined May 16, '05
so is it ok to put it in the vacuum hose connected to the throttle opener? cuz i THINK that's what someone from celicatech sed to do (they had a none working pic and someone in the next post said that is probably the throttle opener)
This post has been edited by elvasoshexai: Oct 29, 2006 - 12:31 AM
06 Civic EX
My For Sale Thread
post Oct 30, 2006 - 2:00 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(lagos @ Oct 28, 2006 - 10:59 AM) [snapback]497035[/snapback]
car is running GREAT!! i need a new belt because the ac condenser pulley is bent and its fraying the edges of the belt (motor came like that) and the stock BOV has a leak in it (constantly pushes out air even when idling) but other than that! im good! going to install guages sometime this week and hopefully a boost controller SOON so i can get up off of only 8psi!
and im definately trying to get back to ny soon shin, im scared to drive all the way up with the swap tho (engine may overheat) frown.gif
sea foam is pretty safe for tubos rite?
This post has been edited by easternpiro1: Oct 30, 2006 - 2:02 PM
post Oct 30, 2006 - 2:22 PM
shin
Joined Aug 21, '04
From New York City
why would it overheat?? not enough cooling?
~*MuH NeW RiDe*~
post Oct 31, 2006 - 3:11 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
yeah its fine for the turbo, My buddy uses it with every oil change in his a4 1.8t. the only thing you should do when you run the seafoam, is change your sparks soon. the amount of exaust and the amount of carbon reall f's with you plugs, makes em all black.
As far as putting it in your oil, i use it with every other oil change b4 i drain it. When i took off my valve cover, ii was amazed at how clean it looked, it really deals with oil sludge (minimal in our cars, more so in turboed engines)
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Oct 31, 2006 - 3:57 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i used something similar to that when i first got my car repaired last year, though i did it at night when no one was around. i wouldn't recommend using it in residential areas... ya might want to go somewhere out of the city and drive it on the hwy at higher rpms to really shoot the carbon build-up out and circulate the engine.
it really feels like it revs a bit faster and smoother..
i added it to my sister's 5th gen with 400,000 kms (yeah) and it made such a difference in power. though try not to use it too often..
post Oct 31, 2006 - 5:16 PM
bigal004321
Joined Jun 21, '05
From New york
The only problem with sea foam is that you may have a small leak somewhere in your engine, but was blocked off by all the sludge. when you run the sea foam through the engine the sludge breaks loose allowing it to leak again.
Bigal
I have a bottle but have never yet used it, maybe someday when i am brave enough..lol
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post Oct 31, 2006 - 5:31 PM
elvasoshexai
Joined May 16, '05
i just used it yesterday... wasn't that much smoke. not sure if i noticed any gain in power... probably very minimal.. but it drove smoother than b4, that's for sure. gonna change my oil in a week or 2 and see how much crap comes out of it
This post has been edited by elvasoshexai: Oct 31, 2006 - 5:32 PM
06 Civic EX
My For Sale Thread
post Oct 31, 2006 - 7:46 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i plan to use it soon, hopefully it wont leak since its a newer engine (1999) but shin, it overheated when i came back from tweak's (4hr drive) maybe the thermometer got stuck?
Lo-Fi Version Time is now: December 4th, 2024 - 4:35 AM
