> Boost issue
post Oct 28, 2006 - 9:39 PM
Punisher
Joined Jun 19, '06
From Portland, OR
So I'm finally driving my swap ... rebuilt 3sgte with gt28 turbo.. it runs great.. however I have an issue when I come into boost.. typically around 6-9psi.. the engine will stutter and if I keep the peddle down it will clear up..
Any thoughts on this? I know it's kind of a vague description but that is pretty much what happens.. just stutters.. and I know it's not fuel cut cuz I don't see the CEL flash and I'm not anywhere near fuel cut pressure.
I'm thinking that it's either
1. ign. timing
2. throttle position sensor (needs to be adjusted)
Other than that it pulls well...
87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
post Oct 28, 2006 - 10:15 PM
it could be knock response too
post Oct 29, 2006 - 12:04 AM
Punisher
Joined Jun 19, '06
From Portland, OR
Well I'm gonna pull the ign. timing back a smidge and see if that clears it up or not. I'll post tomorrow with the results. I gotta make that knock led.
post Nov 1, 2006 - 12:17 PM
lazzyboy121
Joined Feb 17, '04
From michigan
u might want to check if u have ne boost leaks......
it would be also u plugs, wires, or distributor.......
wut kind of plugs are u using?
94 celica GT
92 honda prelude si<h22 swap>
93 eagle talon TSI <4G63 powered>i wish it was AWD
90 mitsu eclipse GSX<4G63 powered>SOLD
LEXUS IS300< im looking for one!
Lo-Fi Version Time is now: February 25th, 2025 - 8:09 AM
