> Engine Knocking, just need some ideas
post Oct 29, 2006 - 6:33 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Well I took my car for a trip, and probably the last. My engine starting knocking really bad. Before it was a tap, now it is definitely a hard knock. It sounds really bad. It is coming from around the valve cover but then again it is sort of from the middle of the engine, hard to tell. I just need some thought on what it might be not exact. So I can kind of get an estimate of how much this is going to cost to fix. Hopefully I don't need a new engine, it would be nice, but I don't have the money right now.
thanks in advance
post Oct 29, 2006 - 8:40 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
sounds like you spun a bearing, is/was the oil low?
post Oct 29, 2006 - 10:08 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
afterwards it was low, before it had enough
post Oct 29, 2006 - 10:19 PM
Bitter
Joined Mar 11, '06
the clunking increases with an increase in rpm? drop the oil pan and take off the rod caps, see whats going on in there.
post Oct 29, 2006 - 10:28 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
yeah the knocking gets a louder and faster with an increase in rpm.
post Oct 29, 2006 - 11:07 PM
Bitter
Joined Mar 11, '06
i'm willing to bet its a spun bearing. how sure are you that your oil wasnt low prior to this? i mean if it was full last month, then its possible you have an oil leak you dont know about and it got low and then bam spun the bearing, and thats why it was low after the bearing spun. check around the engine for oily sludgy stuff, i bet you had a leak you didnt know about.
post Oct 30, 2006 - 9:18 AM
bobw
Joined Mar 30, '05
From Schuylkill County, PA
I agree, definately sounds like a rod bearing. I've heard that sound a few too many times. I'm willing to bet its prolly on number 1 rod cuz that seems to be the first to go but make sure to check all bearings.
post Nov 15, 2006 - 11:16 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Alright guys I'm back. I changed out the rod bearings...#4 was smashed kinda like stretched thin. 1,2,3 were fine but I changed them any way. Well I still have almost the same problem the knocking isn't as bad but it is still knocking. Could it be the valves or something to do with the valves? Any body have any experience with knocking and how did you fix it?
Thanks
Again
This post has been edited by 94st_santos: Nov 15, 2006 - 11:19 PM
post Nov 15, 2006 - 11:52 PM
hitcachi
Joined Jun 19, '05
From Nebraska
Is it knocking or clicking? Clicking is just the valves and their general wear and tear. happens to almost every engine. They just need to be reseated. And many guys go without ever even doing that, because well, its just that common and not that big of a problem.
post Nov 17, 2006 - 11:37 AM
94st_santos
Joined Oct 3, '05
From Houston, Texas
It is definitely a knock. I was looking at the cams the other day and intake cam is not aligned with the exhuast cam. So Im gonna fix that this weekend and see what is does hopefully it'll fix my problem. I'll let you guys know. If anybody has anymore ideas it is appreciated.
post Nov 18, 2006 - 9:43 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Well I aligned the cam and it helped. The tapping I had before my car messed up and during is now gone. It is really quite during idle. Sadly the hard knock isn't gone, it still knocks when I press on the gas. Tomorrow I'm going to check the vavles and see if that's the problem.
So close..
post Nov 19, 2006 - 10:21 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
Well turns out the problem is still the rod bearing. Since running it with the smashed bearing, I think it ate down on the crankshaft and it still leaves a gap to knock. Does anybody know where I can get it grinded down?
post Nov 19, 2006 - 10:55 PM
Yellow94GT
Joined Mar 17, '06
QUOTE(94st_santos @ Nov 19, 2006 - 10:21 PM) [snapback]503882[/snapback]
Ask for a reputable machine shop in your area that can turn the crank and allow for a larger bearing to be used. Most circle track or drag strip enthusists know who does the best work.
Yellow94GT
This post has been edited by Yellow94GT: Nov 19, 2006 - 10:56 PM
Lo-Fi Version Time is now: February 25th, 2025 - 4:54 PM
