> car is leaking oil, turbo celica st
post Oct 30, 2006 - 3:08 PM
trdcelica94
Joined Apr 29, '03
From socal
hey i just got my car back from the shop its a 94 celica turbo im leaking oil bad from the head of the engine like the sides of the valve cover an it looks like from oil pan gasket has this happened to anyone is it expensive to fix this someone said i might have blow a gasket i need help aim ucsdasian619 or pm thanks guys ill post pics soon haha
post Oct 30, 2006 - 3:58 PM
nate95
Joined May 5, '05
From mattoon, IL
hey, mine was doing that right after i got it turbo'd, it didn't do it much and now its not doing it anymore...does your turbo have an oil restrictor in the feed? i have an oil problem, but i have oil coming out of the turbo its self, like threw the fan blades, and oil is going out the exuahst and out of the compressor out let, its blowing oil into my piping frown.gif and i do have an oil restrictor.
post Oct 30, 2006 - 5:13 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
i bet your pcv system is allowing boost to enter the engine, blowing oil out all of the seals. get something called a krankvent http://www.et-performance.com/turbo.html
i've seen them work wonders for other cars that were aftermarket FI, cars that were blowing oil from seals, blowing oil into the intake system off boost, and popping dipsticks. it all stopped happening with the krankvent.
post Oct 30, 2006 - 7:12 PM
trd94
Joined Jan 9, '05
From green springs ohio
what you need is a oil catch can so the boost is not feeding right to the pcv system , nate your problem is your oil return line i have the same problem , i just got done reworking my oil return line to a 3/4 copper flex line and that seems to help a lot i only see oil smoke at 12-14psi i also use two reducers in my feed line ,
post Oct 30, 2006 - 9:45 PM
trdcelica94
Joined Apr 29, '03
From socal
thanks for the help guys i have an oil catch tank i got it checked i need a new valve cover gasket so gonna do that an see what happens ill post pics of the set up soon so i can get feed back on it
Lo-Fi Version Time is now: December 2nd, 2024 - 3:55 PM
