Enthusiast ![]() Joined Mar 24, '06 From East Berlin PA Currently Offline Reputation: 0 (0%) ![]() |
I have a 1994 toyota celi GT and I'm not sure what plugs to get for it. I was wondering if i could get any suggestions on which ones to get??
![]() Enthusiast ![]() ![]() ![]() Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) ![]() |
ngk
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
oem
Enthusiast Joined Oct 24, '06 From atlanta,ga Currently Offline Reputation: 0 (0%) ![]() |
toyota spark plugs from the dealer oem like LewFX said I have had lots of customer come back with celica and camry becuase of some aftermarket spark plugs gave them trouble
Enthusiast ![]() Joined Dec 9, '05 From Calexico CA Currently Offline Reputation: 0 (0%) ![]() |
so oem are better than ngk iridium spark plugs? What about the spark plug cables?
aren't oem for the 7afe and 5sfe ngk? i know for sure oem for the 7afe is ngk
hi
not sure if ngk make toyota there spark plugs or not can find out tomorrow though. I would buy toyota cables also because toyota make all there prouducts just for toyota. unless your race your celica go with the more expence stuff. Just drive for fun and to work stick with Toyota plugs and wires. answer pure dx I can look it up tomorrow but Ngk is a lot more then toyota spark plugs. If they are then why not buy toyota spark plugs if Ngk make them for toyota This post has been edited by celica95gt: Nov 1, 2006 - 3:01 PM |
you dont need irridiums, platinum work just as good
![]() Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) ![]() |
I'd prefer denso iridium/platinum plugs,or even ngk. Don't use domestic plugs like bosch, autolite, etc.
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) ![]() |
Yeah, Platinums last longer. I have Bosch +4 Spark Plugs. They work great with aftermarket spark plug wires. Noticable.
toyota recommends denso or NGK plugs.
oem wires, cap, and rotor will be the best solution, and longest lasting. -------------------- Former Team 5SFTE pro member ;)
QUOTE(ExSane @ Nov 1, 2006 - 11:48 PM) [snapback]498556[/snapback] Yeah, Platinums last longer. I have Bosch +4 Spark Plugs. They work great with aftermarket spark plug wires. Noticable. how long have you been running those plugs without misfire? -------------------- |
Enthusiast ![]() Joined May 5, '06 Currently Offline Reputation: 0 (0%) ![]() |
yeah i have the platinum +4 and actually i noticed a little bit plus i have the nology wires too but for the money its not worth it, and ive been having mis firing and im taking those out either tonight or tomorrow.
![]() Enthusiast ![]() ![]() Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) ![]() |
Denso is the way to go, came on the car and recommend it stays on the car.
![]() Enthusiast ![]() ![]() ![]() Joined Jul 31, '05 From Southern California Currently Offline Reputation: 7 (100%) ![]() |
i have the bosch +4 and not too happy with them thus far... i'll be getting some NGK's tomorrow
it says on the car that they are to be replaced with ngk plugs... so i shall listen to toyota ![]() -------------------- |
good idea, stick with japanese plugs not us..if you get ngk plugs, get ngk wires...everything is cheaper on ebay btw
since i have nology wires should i get nology plugs as well?
yea I would get toyota plugs and wires,any other plugs or wire not going to give your more horse power. I would be toyota plugs they will last a long time.
Enthusiast Joined Nov 11, '06 From Sacramento, CA Currently Offline Reputation: 1 (100%) ![]() |
Here's a spark plug question:
The 1999 Toyota Repair Manual says to replace with either DENSO made PK20TR11 or NGK made BKR6EKPB11 - both platinum multi-ground Haynes and sparkplugs.com say NGK BKR6EP11 - a double platinum Obviously I'm inclined to go with the Toyota Repair Manuals recommendation but was wondering which should be used and what kind of a difference it would really make. P.S.: I've also heard of some people using plugs one heat range colder in California because the gas is "crappy and oxygenated". Any thoughts on this? |
QUOTE(pure_dx @ Nov 1, 2006 - 12:18 PM) [snapback]498291[/snapback] aren't oem for the 7afe and 5sfe ngk? i know for sure oem for the 7afe is ngk Denso is OEM. -------------------- ![]() |
Lo-Fi Version | Time is now: February 18th, 2025 - 7:32 PM |
