> car wonr move into gears, also some of the electrical stuff wont work
post Oct 31, 2006 - 6:41 PM
trdcelica94
Joined Apr 29, '03
From socal
bascially this is what happened changing the valve cover gasket there was a hose in the way the bolt was near the alternator it spark when i tried to unbolt it then i realize i must remove the battery so i did then i did everything put everything back together now a the dash light wont turn on the signal lights and the car wont move into gears so someone saidi blew some fuses i change the fuses in the inside still no light working radio dash and car wont move into gears any idea wat happpened an what to do im panicing thanks
post Oct 31, 2006 - 8:07 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
stick or automatic? did you check your amp fuse? the bigger looking fuse?
IPB Image <--- I miss :'' (
post Nov 2, 2006 - 12:10 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
it's your 100 amp main fuse it's in the fuse box under the hood.
Lo-Fi Version Time is now: November 24th, 2024 - 8:24 AM
