> is it true about the crown of the road, alignment issue or what?
post Nov 1, 2006 - 9:44 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
okay i just had an alignment done last weekend. steering wheel is finally straight and car seems straight. i got my wheels re-balanced and rotated. i put on my old rotors because i think the fronts got warped. anyways i want my car to drive straight but it still drifts a tad to the right if i let go the steering wheel for more than 5 seconds...what is causing this. myth or fact about the crown of the road is slightly right and causes cars to drift? my gf's accord stays straight, why cant my celica???
post Nov 1, 2006 - 9:53 PM
Shocker
Joined Mar 23, '06
From Nashville Tennessee
yea most roads are a parabola (or how ever you spell)so that the rain slides off so it does have a slight curve in the road..
post Nov 1, 2006 - 10:23 PM
celicaST
Joined Jun 23, '05
ya mine drifts to the right usually too, its the roads curvature, dont worry about it. but to make sure, take it to a road or parking lot that you know is relatively flat and see if it drifts.
post Nov 1, 2006 - 11:05 PM
LewFX
Joined Jan 28, '05
how come in my gf's accord its straight.
post Nov 1, 2006 - 11:11 PM
Jaws4God
Joined Mar 27, '04
yeah same here.. just got it aligned and it drifts right.. but seems it does even on flat roads.... so i'm wondering if the rear wheels are out of whack...
post Nov 1, 2006 - 11:12 PM
gt_driFFter
Joined Nov 29, '04
Our cars require 4 wheel alignments because they have INDEPENDENT rear suspension. So your rear alignment should be fine, jaws.
post Nov 1, 2006 - 11:13 PM
Jaws4God
Joined Mar 27, '04
QUOTE(gt_driFFter @ Nov 2, 2006 - 4:12 AM) [snapback]498531[/snapback]
yeah and i'm gonna take it back and see what they say.. .i'm just worried they will say the front is fine.. but I know when I had the bags installed they adjusted the rear.. but after i got springs, the guy said they dont mess with the rear so IDK if its still off from when I had the bags..
idk.
This post has been edited by Jaws4God: Nov 1, 2006 - 11:14 PM
post Nov 1, 2006 - 11:14 PM
check you r tire pressure, make sure they are all the SAME and at about 32psi.
post Nov 1, 2006 - 11:15 PM
gt_driFFter
Joined Nov 29, '04
If you paid for a 4 wheel alignment, then they should have adjusted the rear, they WILL be out of wack even from just installing lowering springs. They might have charged you for a 2 wheel alignment, but as I said, our car's need 4-wheel so either way, I'd go back asap
post Nov 1, 2006 - 11:38 PM
LewFX
Joined Jan 28, '05
i got a 4 wheel one, all my tires are at 35psi
post Nov 1, 2006 - 11:45 PM
Jaws4God
Joined Mar 27, '04
how much should a 4 alignment cost vs a 2 wheel?
post Nov 1, 2006 - 11:48 PM
OntarioCeli
Joined Jul 3, '06
From Brantford, Ontario
Not exactly sure but could that be that one wheel is driving something like torque steer i guess???
post Nov 1, 2006 - 11:54 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(Jaws4God @ Nov 1, 2006 - 11:45 PM) [snapback]498553[/snapback]
$60. Any shims required, about $90-$120.
2 wheel is like $35
This post has been edited by hitcachi: Nov 1, 2006 - 11:55 PM
post Nov 2, 2006 - 12:50 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
isnt 35 psi for low pro tires a little high?
post Nov 2, 2006 - 1:32 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(tim86 @ Nov 2, 2006 - 12:50 PM) [snapback]498729[/snapback]
if you have a 40 profile I'd bring it down to 30psi. but if you don't drive long distances it should be perfectly fine. and as long as they are all the same it wouldn't be the cause of the pulling.
I had my Kumho's at 35 and got bulges after long drives and had to replace them twice... but those were sh!tty tires. my 45 profile Falkens are at about 32 with no problems.
I <3 Dustin---07/16/06
post Nov 2, 2006 - 2:12 PM
Rayme
Joined Feb 18, '06
From NB, Canada
Your GF'S accord has probably balloon/high profile tire..they are less distrubed by road deformity...
-Rémy
02 SiR, 08 250R
post Nov 2, 2006 - 10:13 PM
LewFX
Joined Jan 28, '05
i got 225/45/17s
post Nov 3, 2006 - 12:28 AM
Fate
Joined Nov 30, '04
From Atlantic City
i have the same problem, i just always figured it went to the right a little as a "safety" feature. for example, if you fall asleep at the wheel it will go into the guardrail before on-coming traffic.
yeah...retarded i know.
post Nov 3, 2006 - 12:49 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(Fate @ Nov 3, 2006 - 12:28 AM) [snapback]498993[/snapback]
assuming theres a law against traveling in the left lane and you are actually following that law. and it doesn't account for RHD...
post Nov 3, 2006 - 12:31 PM
Fate
Joined Nov 30, '04
From Atlantic City
^haha, somebodys gotta.
Lo-Fi Version Time is now: November 30th, 2024 - 5:54 PM
