> Car stalled, will not start, crap!
post Nov 5, 2006 - 9:24 PM
Rayme
Joined Feb 18, '06
From NB, Canada
damnit I just lost the paragraph I just typed..I<ll make it short. I need help fast!!!!
Car stalled with no warning. Engine turns over with no sign of life(just fuel smell).
Its NOT fuel related, pump is working. There is NO SPARK, its an ignition problem.
Car will still not start hours later, no hesitation at all, just turning in the butter!
Map sensor, coolant temp sensors are ok.
We tried a working ignitor, not better.
New spark plugs, cap and rotor.
All fuses are ok, as well as obvious systems likes EFI, relay is clicking, etc..
At this point we're thinking its either the coil or crank angle sensor. I'm trying to gather as much info as my car is stranded on Prince Edward Island and its fraking 40$ of bridge toll to get there (I live in NB), so my friend and I want to go there with a bunch of spare parts and hopefully start the ''beast'' again. I'm pretty sure a new distributor assembly will take care of it..but I need to think of everything that can possible stop sparks from happening!
Thanks for all your help and experience!
This post has been edited by Rayme: Nov 5, 2006 - 9:28 PM
-Rémy
02 SiR, 08 250R
post Nov 5, 2006 - 10:40 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
hmm CAS would also disable fuel. get the manual from celicatech and check out the wires going to the distributor for the correct power levels. is your check engine light on when the car is Key On Engine Off? if its not then your PCM has a problem, if its on then thats probably ok. check for any codes tho, there could be somehthing there that could point you in the right direction.
post Nov 6, 2006 - 6:23 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
engine light is on when key is in "ignition"
all relays are working
Rayme tried pulling a spark plug and grounding it on the block, no spark
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Nov 6, 2006 - 8:20 PM
Bitter
Joined Mar 11, '06
so are the plugs wet after cranking?
post Nov 6, 2006 - 8:24 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
bah, its the coil pack.....hmmm, honestly i dont know, but when i had a problem like this, it was either a ground or the coil....( from two different situations mind you)....but anyways, goodluck....
(\__/)
post Nov 6, 2006 - 10:22 PM
K-ESD
Joined May 5, '05
QUOTE(3WayStunna @ Nov 6, 2006 - 9:24 PM) [snapback]500082[/snapback]
which ground gave you trouble?
thanks for the input
post Nov 7, 2006 - 7:00 AM
Rayme
Joined Feb 18, '06
From NB, Canada
Upon further research, I found anothing this that might be bad. The pick up coil inside the distributor. .. But we'll knew Wednesday eh Nick? lol
I just hope its nothing like a freak accident (like broken wire inside a loom).
-Rémy
02 SiR, 08 250R
post Nov 7, 2006 - 7:59 AM
3WayStunna
Joined Jun 25, '06
actually to be honest, the igniter, i know on my 3sfe and 3sge engines, are grounded (through their bodies) to the frame, by being bolted to them...i had removed my ignitor from the frame, and couldnt get my car to start......so i ran a ground from my igniter to the frame, and voila, instant start....dosent sound like your case though....
(\__/)
post Nov 7, 2006 - 9:17 AM
Negative
Joined Apr 28, '04
From Houston, Texas
This happened to me and it was the coil. Replaced with $45 MSD coil and no problems. You will need to mess with the coil wire by adding the oldsckool style male spark connection that you should get with the coil to your coil wire. Was pretty easy though. Just made another one the other day when I got my NGK Ultimate Race wires.
post Nov 7, 2006 - 7:25 PM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(Negative @ Nov 7, 2006 - 10:17 AM) [snapback]500228[/snapback]
How could I use an aftermarket coil (I'd like too! cheaper!) when the stock one is inside?? The "coil wire" is just a brass lead inside the cap..I can't picture it!
-Rémy
02 SiR, 08 250R
post Nov 7, 2006 - 10:56 PM
lazzyboy121
Joined Feb 17, '04
From michigan
could it be teh timing belt snapping? fuel would be there but no spark cos of the cams not turning.....
94 celica GT
92 honda prelude si<h22 swap>
93 eagle talon TSI <4G63 powered>i wish it was AWD
90 mitsu eclipse GSX<4G63 powered>SOLD
LEXUS IS300< im looking for one!
post Nov 8, 2006 - 6:59 AM
K-ESD
Joined May 5, '05
QUOTE(lazzyboy121 @ Nov 7, 2006 - 11:56 PM) [snapback]500454[/snapback]
i thought about it but if the timing belt snaped, wouldn't it be heard flopping around when cranking?
post Nov 8, 2006 - 7:46 AM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(K-ESD @ Nov 8, 2006 - 7:59 AM) [snapback]500569[/snapback]
Anyway we got hold of a whole distributor (including a working coil, pickup coil and crank angle sensor)..So I can at least bring my car home, and diagnostic what's wrong!
This post has been edited by Rayme: Nov 8, 2006 - 7:47 AM
-Rémy
02 SiR, 08 250R
post Nov 10, 2006 - 3:37 PM
Rayme
Joined Feb 18, '06
From NB, Canada
great! that spare distributor worked! I just ordered a compleletely neww one..I didn't want to look at at what
exactly went wrong..
-Rémy
02 SiR, 08 250R
Lo-Fi Version Time is now: November 30th, 2024 - 6:52 PM
