> Idles rough., As stated above....I have a really rough idle.
post Nov 6, 2006 - 2:05 AM
THCelica
Joined Jun 24, '06
From Memphis, TN USA
Ok....Here is what I got. When I first start my Celi it idles really rough. And does so until the engine is warm. And when I first put it in gear while its cold it does the same. What could be the issue. Like when I put it in to gear with the brakes pressed before taking off and causes the whole car to shimmy. I know this probably doesn't help describe it all the way but any insight would be appreciated!!
This post has been edited by THCelica: Nov 6, 2006 - 3:47 AM
post Nov 6, 2006 - 11:00 AM
sn0wfr0g
Joined Feb 27, '05
From Austin, TX
QUOTE(THCelica @ Nov 6, 2006 - 1:05 AM) [snapback]499822[/snapback]
dont know if this could be related but it sounds like it might. we did some massive troubleshooting on mine to locate the source of a very similar problem and came to find out that the distributor was leaking oil into the cap.
replaced the cap and everything went back to normal. only problem is the o-ring in the distributor still leaks so i can already tell that the idles are getting worse again.
FYI: a buddy of mine who has been helping me work on my ride posted this:
http://www.toyotanation.com/forum/t163502.html
which has some links to kits to resealing the distributor.
hope this helps.
-Jimi
Lo-Fi Version Time is now: November 22nd, 2024 - 8:52 PM
