> Engine check light
post Nov 7, 2006 - 1:19 AM
CelicaST202
Joined Apr 2, '06
From Socal
I was driving for around for 5mins, then the engine check light came on. After shutting the car off for about 3-4 hrs the light went away. Any suggestions whats going on? BTW its a 94 Celica.
post Nov 7, 2006 - 1:34 AM
4g-gt-four
Joined Oct 16, '06
From colorado
read the code. connect e1 and te1 in the diagnostic connector then count the sequence the check engine light blinks. It should blink a number of times, then pause a sec, then blink another number of times. for example, if it were code 54, it would blink blink blink blink blink-pause-blink blink blink blink. five times then four times would be code 54. find out the code then read in your service manual what the code is. or if you dont have a service manual find out from someone who has it. its prob on the internet somewhere. I only have the codes for a 88-89 and 94-98 3sgte, (some might be the same) then once you know the fault you can begin to troubleshoot it. most of the time it is a defective component. on rare occasions it is wiring or a bad ecu
88 celica all-trac
-st205swap
post Nov 7, 2006 - 1:42 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(Batman722 @ Jul 31, 2005 - 11:00 PM) [snapback]318927[/snapback]
QUOTE(cyb593 @ Jul 31, 2005 - 9:18 AM)
well i bought my 2nd 6gc and it had the check engine light on. well we cleaned the engine bay and when we were done i got in the car turned the car on and the check engine light went off?? anyone know what happened??. also after that it drove fine right. then i parked ot try to drive it and it wouldnt go into first gear so we pushed it into my driveway let it run for about 15 minutes on idle and then it worked again what is going on with this??
[snapback]318682[/snapback]
the ECU stored the code, the problem could still there but just not showing or gone. It could of just been a loose connection or an eratic change in driving style. You could reset the ECU (pull the ECU fuse in the bay (or the neg battery terminal) and wait 30 sec, then reconnect) and check to see if the CEL pops up again.
I <3 Dustin---07/16/06
post Nov 7, 2006 - 1:48 AM
4g-gt-four
Joined Oct 16, '06
From colorado
cwm13.gif its better to know what the code is before you clear it. its not like its hard. it will just help you to look for symptoms related to the fault code. And that way your not wondering what the cods was. connect a peice of wire and watch a light flash..
88 celica all-trac
-st205swap
post Nov 7, 2006 - 10:11 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
^that was explaining why the CEL may have gone off and what to do to try and get it back on to see if the problem still exists, not saying anything about clearing it.
the ECU stores the fault code. find out what it is then go from there.
post Nov 8, 2006 - 10:46 AM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
did u get gas b4 it came on? If it went away it could have just been a small EVAP system leak-gas cap or something- those tend to reset themselves smile.gif
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Nov 8, 2006 - 11:55 AM
CelicaST202
Joined Apr 2, '06
From Socal
QUOTE(nightryder @ Nov 8, 2006 - 10:46 AM) [snapback]500600[/snapback]
Nope didnt get gas
Lo-Fi Version Time is now: February 25th, 2025 - 2:35 PM
