> Stock Rims w/ 205-55-15 Tires, rubbing or something???
post Nov 10, 2006 - 12:51 AM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
ok... i just put my stock 15s back on... the same ones that came with my car that i used for 6 months... before getting my aftermarket rims
afterwards, i went to the gas station... the second i started going out of my garage i noticed it made a sound that sounded either like the tires were rubbing or the tires were flat or a bag was caught onto the tires or something... i'm almost positive it didn't used to make this sound before
so i checked the tire pressure @ the station and it was fine... drove around gas station and it had that sound
the sound only happens @ low speeds...drove home and while going into my garage.. still had that sound...
my aftermarket rims before had hubcentric rings... but those are attached to the actual rim right? they wouldn't get stuck on the hub right?
if it was rubbing brakes/suspension/fenders it would still make that sound even at higher speeds right?
i can't seem to figure out what else is causing it to make this sound...
This post has been edited by elvasoshexai: Nov 10, 2006 - 12:53 AM
06 Civic EX
My For Sale Thread
post Nov 10, 2006 - 1:13 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(elvasoshexai @ Nov 10, 2006 - 5:51 AM) [snapback]501196[/snapback]
Hub centric rings are attached to the outer hub and they help center the wheel. They typically aren't needed for tapered/acorn lugs, but hey. Stock wheels typically are bored perfectly to sit flush on the hub... so leaving one on could screw up the offset and/or cause the wheel to not sit flush. Take off your wheels and check em out!
post Nov 11, 2006 - 1:07 AM
elvasoshexai
Joined May 16, '05
hm. i checked all my wheels and the hubcentric rings are clipped onto the aftermarket rims...
but the problem just magically fixed itself.. so... i guess it's ok
06 Civic EX
My For Sale Thread
Lo-Fi Version Time is now: February 18th, 2025 - 5:09 PM
