![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) ![]() |
im installing 4 12inch diamond audio d3s in my car and i need to kno if i can run off of my reg battery or do i need to get some for of power inverter to push more to the subs so i dont drain my battery???? or if any suggestion i would really appreciate it. Im also lookin to install a tv to so i need to kno wat to do????
![]() Enthusiast ![]() ![]() Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) ![]() |
you def need a deep cycle battery & maybe hunt a cheap uprated alternator if possible to be safe. Power caps will be decided if you feel the need or you like the look
![]() -------------------- My Celica Is Now For Sale
![]() Enthusiast Joined Aug 28, '06 From morristown Currently Offline Reputation: 2 (100%) ![]() |
first thing is first if your not useing a hi watt amp to push them then you would not need any thing but if you are going crazy and stuff then i sugest if you have a good alt. all you need to do is get a optama yellow top gel cell bat. and any 1-3 farid power cap and you will be fine. the main thing the cap will do is keep your lights from flashing ie. headlights dome lights gauge lights
![]() Enthusiast ![]() ![]() ![]() Joined Oct 4, '06 From Kelowna, BC Canada Currently Offline Reputation: 3 (100%) ![]() |
What is your current battery and what amp (model and wattage) are you going to be running these subs with?
There's no point upgrading your battery/alt unless you are going to be pushing their limits. -------------------- ![]() |
I'd have thought running subs like those beautys he'd be running some major amps!
Lo-Fi Version | Time is now: February 18th, 2025 - 7:14 AM |
