Enthusiast ![]() Joined Nov 6, '06 From Toronto Currently Offline Reputation: 0 (0%) ![]() |
3rd Gen 3SGE from a 96' Celica SS-II
super clean, less than 50K included: torque plate or flywheel(your choice), cut wiring harness, MAP, ignitor, ECU, alternator of your choice(Celica or MR2) pick-up only no longer for sale, Im going back to N/A so Im using this for my own application This post has been edited by allblackalltrac: Jun 5, 2007 - 10:07 AM |
![]() Enthusiast ![]() Joined Sep 30, '06 Currently Offline Reputation: 0 (0%) ![]() |
can u put a pic of the whole motor...plz
-------------------- ![]() IT DON'T PLAY! |
I am getting a header I won off ebay, the torque plate is on route and I also have found the ecu for it so it is a complete motor, now.
I'll take a pic of the engine after I install the new cam seals and timing belt. Not that there was anything wrong with the old ones, I swaped the intake cam cause it was originally a manual equipped engine. Gen3 3SGE A/T (170ps): In: 240deg, 8.7mm lift (timing 7/53) Ex: 240deg, 8.2mm lift (timing 53/7) Gen3 3SGE M/T (180ps): In: 252deg, 9.8mm lift (timing 7/65) Ex: 240deg, 8.2mm lift (timing 53/7) Gen3 3SGTE (245ps): In: 240deg, 8.7mm lift (timing 7/53) Ex: 236deg, 8.2mm lift (timing 50/6) I have a 3G 3SGTE head and wanted the longer duration, higher lift cam from the N/A motor hence the swap and the reason for me listing it as a AUTO engine and not a manual - I did not swap the exhaust cam. The engine was missing the header, flywheel and ecu when I purchased it, its only by chance that I was able to find the missing parts. A good friend is interested in it at this point and wants me to put it in his wifes 6G Celica GT A/T, so she gets precidence for now until she changes her mind. My neighbour is also interested in it for his 6G Celica GTS A/T as well. Local's take precidance as its less headache for me to have to deal with shipping it. This post has been edited by allblackalltrac: Jan 12, 2007 - 12:07 AM |
Got the MAP sensor and ignitor needed to complete the swap and make the engine run correctly with the ecu, as complete as your going to find unless you buy a clip.
I got the cam seals in and the timing belt on, engine is now fully assembled, the flexplate you see on the floor behind the motor is the one for this engine, the heat shield you see to the right of it is not for this engine and is the only thing missing from the motor.
the wire harness is cut ?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) ![]() |
I can wire this up for anyone who's thinking of buying it.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
QUOTE(Batman722 @ Jan 7, 2007 - 11:51 PM) [snapback]516027[/snapback] the wire harness is cut ? yes - where it passes through the firewall |
MAP sensor part#: 89420-20300
Ignitor part#: 89621-26010 ECU part#: 89661-2D500 coil part#: 029700-7700 ![]() ![]() ![]() ![]() ![]() This post has been edited by allblackalltrac: Jan 12, 2007 - 12:25 AM |
![]() Enthusiast ![]() ![]() Joined Aug 20, '06 From Kissimmee Currently Offline Reputation: 0 (50%) ![]() |
is there anyway to convert this back to manual
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) ![]() |
Yeah, I would be on this if it had the original JDM manual tranny on it.
QUOTE(rspjean @ Jan 17, 2007 - 9:55 PM) [snapback]518754[/snapback] is there anyway to convert this back to manual Yes, - remove the torque plate and bolt on a flywheel - use a manual ecu QUOTE(ExSane @ Jan 17, 2007 - 10:17 PM) [snapback]518760[/snapback] Yeah, I would be on this if it had the original JDM manual tranny on it. sold it seperatly a long time ago, your stock tranny will still bolt up |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 29, '06 From Kitchener, ON, CA Currently Offline Reputation: 0 (0%) ![]() |
damn!
local too! I'd be all over this if I had the money right now |
QUOTE(allblackalltrac @ Jan 17, 2007 - 11:15 PM) [snapback]518781[/snapback] sold it seperatly a long time ago, your stock tranny will still bolt up Yeah, but I want the JDM gear ratios. Plus, my car is an ST. -------------------- ![]() |
QUOTE(ExSane @ Jan 20, 2007 - 2:09 AM) [snapback]519441[/snapback] QUOTE(allblackalltrac @ Jan 17, 2007 - 11:15 PM) [snapback]518781[/snapback] sold it seperatly a long time ago, your stock tranny will still bolt up Yeah, but I want the JDM gear ratios. Plus, my car is an ST. Well if your car originally comes equipped with the 7A-FE than that tranny will not bolt up to this motor nor will this motor bolt into your engine bay without welding in s-series motor and tranny mount brackets. JDM gear ratios are over rated, I had them - didnt like them. |
QUOTE(allblackalltrac @ Jan 29, 2007 - 10:56 PM) [snapback]522478[/snapback] Well if your car originally comes equipped with the 7A-FE than that tranny will not bolt up to this motor nor will this motor bolt into your engine bay without welding in s-series motor and tranny mount brackets. Exactly my point. So it would help alot if you did had the tranny. Unless the good DrTweak has a 3SGTE (MR2) or 5SFE tranny laying around. I guess there isn't much I can do. Good luck with the sale though. Bump. -------------------- ![]() |
QUOTE(ExSane @ Jan 30, 2007 - 9:53 AM) [snapback]522586[/snapback] QUOTE(allblackalltrac @ Jan 29, 2007 - 10:56 PM) [snapback]522478[/snapback] Well if your car originally comes equipped with the 7A-FE than that tranny will not bolt up to this motor nor will this motor bolt into your engine bay without welding in s-series motor and tranny mount brackets. Exactly my point. So it would help alot if you did had the tranny. Unless the good DrTweak has a 3SGTE (MR2) or 5SFE tranny laying around. I guess there isn't much I can do. Good luck with the sale though. Bump. I don't have one one hand, but GT trannys aren't too hard to find. Also, a manual ECU technically isn't needed, the auto will work fine, though it might have a lower rev limit. I'd buy this whole setup if I had the money to put into my Celica. In fact... what would shipping be to Savannah, GA? -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
QUOTE(Dr_Tweak @ Jan 30, 2007 - 8:49 AM) [snapback]522602[/snapback] QUOTE(ExSane @ Jan 30, 2007 - 9:53 AM) [snapback]522586[/snapback] QUOTE(allblackalltrac @ Jan 29, 2007 - 10:56 PM) [snapback]522478[/snapback] Well if your car originally comes equipped with the 7A-FE than that tranny will not bolt up to this motor nor will this motor bolt into your engine bay without welding in s-series motor and tranny mount brackets. Exactly my point. So it would help alot if you did had the tranny. Unless the good DrTweak has a 3SGTE (MR2) or 5SFE tranny laying around. I guess there isn't much I can do. Good luck with the sale though. Bump. I don't have one one hand, but GT trannys aren't too hard to find. Also, a manual ECU technically isn't needed, the auto will work fine, though it might have a lower rev limit. I'd buy this whole setup if I had the money to put into my Celica. In fact... what would shipping be to Savannah, GA? -Doc So I would need the 5S-FE Tranny to complete the swap? This post has been edited by ExSane: Jan 30, 2007 - 7:36 PM -------------------- ![]() |
QUOTE(ExSane @ Jan 30, 2007 - 7:36 PM) [snapback]522823[/snapback] ![]() Any 5-speed tranny that came attached to an s-series motor ie. 5sfe, 3sfe, 3sge even a 3sgte can be converter to FWD. Also any manual tranny that came from the MR2 or Camry. |
Lo-Fi Version | Time is now: February 21st, 2025 - 8:56 AM |
