Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) ![]() |
I got a map sensor from the junk jard cheap. It came from a single turbo supra. The part# is 89420-14020. Does anyone know if this will work on the 3sgte? Thanks! -toyotacrazy
Enthusiast ![]() Joined Oct 17, '04 From St Louis, MO Currently Offline Reputation: 0 (0%) ![]() |
yeah it should
simple way to check is to hook it up with no vacuum connected to it...you should see about 2-2.5 volts on the outlet pin at 0psi ...if so then it's a 2bar map and that;s what the 3sgte had (some had a 2 bar, some had a 2.2 some had a 2.5) depends on the exact year -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi |
QUOTE(NuclearHappineS @ Nov 13, 2006 - 3:11 PM) [snapback]501943[/snapback] yeah it should simple way to check is to hook it up with no vacuum connected to it...you should see about 2-2.5 volts on the outlet pin at 0psi ...if so then it's a 2bar map and that;s what the 3sgte had (some had a 2 bar, some had a 2.2 some had a 2.5) depends on the exact year I have the sensor off the car. The car doesnt run yet. Could you be more specific on what to check? Is there a continuity check I could do? Or does it need to be hooked up to a car? Thanks! |
![]() Enthusiast ![]() Joined Mar 18, '06 From Brisbane - Australia Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(toyotacrazy @ Nov 13, 2006 - 12:35 PM) [snapback]501748[/snapback] I got a map sensor from the junk jard cheap. It came from a single turbo supra. The part# is 89420-14020. Does anyone know if this will work on the 3sgte? Thanks! -toyotacrazy I read somewhere these were the same voltage as the 89420-17030. I purchased one brand new. They do not work. Voltage at 0PSI is .2v |
Lo-Fi Version | Time is now: February 17th, 2025 - 6:43 AM |
