Oil leak..., oil pan maintenance help. |
Nov 13, 2006 - 8:25 PM |
Enthusiast Joined Feb 24, '05 From Fresno, California Currently Offline Reputation: 5 (100%) |
hey 6gc's owners. well i have a problem. Some kind of oil is leaking under my car a littler further up near the oil drain bolt. I did my oil change a month ago and while under the car, i noticed the area near my oil pan, the passenger cv boot were all greased up. I scan through the whole underneath of the car to the area i'm guessing it could be leaking from. I know it's not from the oil drain bolt cuz there weren't that much oil from there. but when i slide my finger across where the oil pan is screwed onto, where i'm guessing there should be a seal, it was pretty oily. So my question is that if anyone had remove the oil pan and place a new seal on their oil pan. if so, is it easy to do yourself, or do it require a lot of work. Need your guys help on this. or if there's another reason where the leak can be coming from. thanks for your time 6gc owners.
Nov 13, 2006 - 9:31 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
not too hard. when you take it off.. take time to clean the pan. a steel brush and plenty of blades will do the trick. Use Toyota RTV.. They don't dry instantly.. [only RTV we use.. ]
Consist of plenty of 10mm bolts |
Nov 14, 2006 - 9:52 PM |
Thanks for the help jdg371, i also read some of the past posts, they too were a lot of help.
QUOTE(jdg371 @ Nov 13, 2006 - 9:31 PM) [snapback]502093[/snapback] not too hard. when you take it off.. take time to clean the pan. a steel brush and plenty of blades will do the trick. Use Toyota RTV.. They don't dry instantly.. [only RTV we use.. ] Consist of plenty of 10mm bolts This post has been edited by jAzn95GT: Nov 14, 2006 - 9:54 PM |
Lo-Fi Version | Time is now: November 27th, 2024 - 10:27 PM |
