> 157,000 to late to turbo?
post Nov 15, 2006 - 6:13 PM
Bbuck35
Joined Oct 8, '06
From LSMO
hey just wondering what you guys think, is 157,000 miles on a 7AFE to late to turbo , or should i invest in a rebuild 3SGTE swap. ?
let me know ...
How far can it take you. The real question is. How far are you willing to go ?
post Nov 15, 2006 - 8:33 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
get a compression test. and if you want more power and have the money, go 3s.
post Nov 15, 2006 - 11:24 PM
InfamousChappy
Joined Sep 30, '06
From Knox Vegas, Tennessee
The 7afe, in my opinon doesn't create optimal power at low rpms. With a turbo this is where you wouldn't have the power.
My 7a blew around the mileage mark that yours has. All that was done to mine was headers and a CAI.
My first and current transportation is a 1990 BMW 325i. Straight six that puts out around 200 hp, maybe more I have forgotten the exact numbers.
My point is this..When I got my celica, which is now my fourth vehicle and 2nd car (I had two SUVS that met their demise..I'll never drive another) I felt like it had no power atleast compared to my BMW. So whatever horsepower you feel you can handle, go with that. Just realize the 7a has less (even with a turbo) than a 3s.
post Nov 16, 2006 - 3:44 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
long term go 3s, more than likely has fewer miles and is in better condition
post Nov 19, 2006 - 11:33 AM
6strngs
Joined May 12, '06
From Wilmington, NC
I have a similar question. My 5sfe has 150,000 (almost 151 now!) and I want to turbo it, but I'm not sure about it... I mean, the engine runs fine now, but I don't want to drop a couple grand into an engine for a turbo only to blow it within a couple thousand miles because of the added stress. could it take it? or would rebuilding it or buying a new 5sfe be my only real option for turbo-ing?
post Nov 21, 2006 - 2:46 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(6strngs @ Nov 19, 2006 - 8:33 AM) [snapback]503727[/snapback]
that mileage is pretty high to deal with the added stress of a turbo, there are probably parts that are worn in and perform just fine with the motor as it is, such as piston rings, cylinder walls, and crank journals. With suck high mileage the parts are already pretty worn. They probably wont last very long under boost. You might get lucky and not have any problems, but with the money your gonna spend on the kit, i would probly just save a little more and get a 3sgte and use your tranny (its cheaper) Good luck! smile.gif
post Nov 21, 2006 - 5:53 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Ok, this is strictly opinion, but I feel that at that kind of mileage (I have the same and have been researching the same thing) should be fine if you car hasn't experienced any kind of severe problems already. However you are going to want to take extreme measures in preventative maintenance. i.e. Intercoolers are typically used to lower temperatures on higher output turbos but in our case we'd want to use one on a small T3 on only 6-7 psi. You won't push much but you'll notice an incredible difference. Most have noticed late 14's, which isn't bad at all if you're looking for a comfortable daily driver. So keep in mind that you're going to cause quite a bit of damage if you just do the necessary turbo components, be sure to upgrade what you can with the life of your engine in mind versus the potential power.
As for the whole 3SGTE thing with the "faster engine that will more than likely be in better condition"...look at it this way, you turbo your 7A - if it blows up you can get a super cheap new one because everyone else is too busy swapping a 3S into theirs...
This post has been edited by GTS13: Nov 21, 2006 - 5:54 PM
post Nov 21, 2006 - 11:22 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(eggman40 @ Nov 21, 2006 - 11:46 AM) [snapback]504275[/snapback]
I live in california. it's near-impossible to make one legal... though, now apparently someone is saying it is legal if you install all the emission control stuff on it. but even then, it would have to be a 94+ so I might only be able to get a 3rd gen, which is even more money...
post Nov 22, 2006 - 12:27 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(6strngs @ Nov 21, 2006 - 8:22 PM) [snapback]504416[/snapback]
I live in cali and i "made" it legal wink.gif but its really up to you
Edit: its not like the turbo kit you put on the motor now would be street legal anyway, so if your gonna get popped for an illegal mod, you may as well make it worth your while and get a 3sgte.
This post has been edited by eggman40: Nov 22, 2006 - 12:29 PM
post Nov 22, 2006 - 4:36 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
It's all a matter of how different do you wanna be, if I wanted to do what everyone else does *cough*3SGTE*cough* I would have bought a Honda. biggrin.gif But I'm just weird like that.
post Nov 22, 2006 - 4:42 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(eggman40 @ Nov 22, 2006 - 9:27 AM) [snapback]504516[/snapback]
how did you "make" it legal?
post Nov 22, 2006 - 5:31 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I got a compression test done on my car today
cyl 1 cyl 2 cyl 3 cyl 4
100 130 110 130
how do they look for a turbo ? not too good ?
post Nov 22, 2006 - 5:58 PM
QUOTE(Culpable04 @ Nov 22, 2006 - 5:31 PM) [snapback]504591[/snapback]
100 130 110 130
I would have to say not too good
post Nov 23, 2006 - 12:42 AM
Culpable04
Joined Apr 17, '06
From New Jersey
yeap ! that's what I figured, so my christmas present will have to be delay kindasad.gif I'm gonna get another 7AFE and build it a little, I don't want 300 HP out of it I think I'll ok fine with 180-200 HP
post Nov 23, 2006 - 3:18 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Batman722 @ Nov 22, 2006 - 2:58 PM) [snapback]504606[/snapback]
100 130 110 130
alright, so if I run a compression test on my cylinders, what kind of numbers should I be looking for to be able to say my engine would be in good enough condition to turbo?
Lo-Fi Version Time is now: February 20th, 2025 - 1:58 AM
