> W.T.B. 3s-gte map sensor, COMPLETED
post Nov 16, 2006 - 7:57 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Hey guys,
I need a 2 bar map sensor for my 3sgte swap. Please pm or e-maiil me. Thanks!
This post has been edited by toyotacrazy: Nov 19, 2006 - 9:52 PM
post Nov 16, 2006 - 8:03 PM
Can you edit your post so that it has a meaningful title? Titles of 'W.T.B." aren't very helpful, and you should have what you're looking for in the title. wink.gif
post Nov 16, 2006 - 8:34 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
heres one
http://www.6gc.net/forums/index.php?showtopic=34487
I <3 Dustin---07/16/06
post Nov 16, 2006 - 10:13 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Coomer @ Nov 16, 2006 - 8:03 PM) [snapback]503072[/snapback]
The way I wrote it up it tells the whole description and nobody has to bother clicking on it unless it applies to them. I think its ok. wink.gif
post Nov 16, 2006 - 10:50 PM
QUOTE(toyotacrazy @ Nov 16, 2006 - 7:13 PM) [snapback]503105[/snapback]
Um...I don't see how "W.T.B." tells someone that you want to buy a 2 bar map sensor. So you need to change your topic title.
post Nov 17, 2006 - 1:16 AM
celicaST
Joined Jun 23, '05
QUOTE(Coomer @ Nov 16, 2006 - 8:50 PM) [snapback]503118[/snapback]
post Nov 17, 2006 - 1:43 AM
4g-gt-four
Joined Oct 16, '06
From colorado
are you trying to use the gm map sensor for an st205 ecu? Because I have heard that they do not work. That is part of the reason i ended up just buying a front clip instead of just the motor. That and a gazilion other parts I would need to source. I also heard that the turbo pressure sensor(map) off of an st165 0r st185 or any other map sensor aftermarket, honda, etc, also will not work with the st205 ecu. You have to buy the expensive toyota gen 3 sensor, which is expensive and incredibly hard to source... But if you are running some sort of standalone that accepts the gm part you should be ok
by the way, coomer has a valid point and he is the administrator.... just change the topic to say wtb 2bar map sensor. He asked nicely
88 celica all-trac
-st205swap
post Nov 17, 2006 - 4:47 AM
QUOTE(celicaST @ Nov 16, 2006 - 10:16 PM) [snapback]503193[/snapback]
Topic descriptions are not titles...it's important that what you want to buy is in the topic title.
Lo-Fi Version Time is now: April 22nd, 2025 - 5:38 PM
