tranny swap list |
tranny swap list |
Jul 3, 2003 - 10:58 PM |
Enthusiast Joined Feb 15, '03 From Michigan Currently Offline Reputation: 1 (100%) |
hey guys...can anyone send me a list of parts that would be needed inorder to do a auto--->manual swap including clutch, linkage and all that stuff...thanks alot!!!
Jul 4, 2003 - 4:46 PM |
Enthusiast Joined Oct 1, '02 From Seattle, WA Currently Offline Reputation: 0 (0%) |
heres the stuff i needed:
-Tranny -Shifter assembly and cables -Flywheel -Clutch Master cyl. -Slave cyl. -New clutch kit -Clutch metal fluid lines (there are two of them) -Rubber clutch line -Flywheel bolts -Pressure plate bolts -Clutch pedal assy. -Manual brake pedal assy. -Tranny fluid -Brake fluid for clutch get everything you can from a junkyard, bc sometimes the only alternative is the toyota dealer, and they are ass expensive. But some things, such as flywheel and pressure plate bolts and the fluid lines cant be found anywhere else. Try looking on car-parts.com for parts in your area. all the parts cost me about $1000, labor is another grand. i got this list from Nemesis3s-gte over at celica.net. He helped me out a lot. Also, try doing a search... there are a few people who have done this swap, including me, and they are all really nice and willing to answer questions. -------------------- Its Orville's Celica, i just drive it... |
Jul 4, 2003 - 4:53 PM |
Thank you....
Jul 4, 2003 - 6:16 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
i have the clutch pedal and brake pedal you will need..(arms and all). the only thing you'll need is the clutch pedal bracket to bolt it into the car. . lemme know if you want them.
-John- -------------------- |
Jul 4, 2003 - 6:34 PM |
thanks...yeah just PM or e-mail me with more info, definitely interested!
Jul 4, 2003 - 11:04 PM |
if you are doing the auto~~~>manual swap why not go with the 3S-GE tranny???
it costs about the same you can get it from a JDM SS-III |
Lo-Fi Version | Time is now: November 25th, 2024 - 3:42 PM |
