365cc injector too big? |
Nov 21, 2006 - 11:42 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
Finally, i went to dyno tuned my toyota corolla 7AFTE by using emanage blue. Found out i was running freaking rich whn offboost and I was being told my injector was too big for my setup as Im using 4AGZE 365cc injector. I've replaced stock map to 3bar Haltech map sensor.
dyno result showed 160whp with quite a few problem exists (not totally related with injector issue). So may i have some gurus opinion on this. Issit 365cc injector was way too big for a 160whp setup car? I do not have an adjustable fuel regulator to control. so i need one? As i was being told, emanage will only take over the fuel control after 25% throttle load. As before, its still using stock ecu to control the fuel load. Can this be the reason why its running too rich? seriously need help here.... |
Nov 25, 2006 - 3:11 AM |
Enthusiast Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) |
365cc injectors should be fine, its all down to the duty cycle signal given by the ecu. I dont know much about the emanage but it sounds more suited to the stock injectors for your motor if you dont have full duty cycle control with it. I run 800cc injectors controlled by an Apexi Power FC which has full injector control and is just fine.
-------------------- 1994 JDM GT4 WRC
Nov 25, 2006 - 10:10 AM |
Nuke nows what he's talking about. He already answered your question at celicatech:
http://www.celicatech.com/forums/showthread.php?t=21458 -------------------- Project ST204.5 99.88946% complete... |
Nov 25, 2006 - 11:15 AM |
QUOTE(WannabeGT4 @ Nov 25, 2006 - 10:10 AM) [snapback]505166[/snapback] Nuke nows what he's talking about. He already answered your question at celicatech: http://www.celicatech.com/forums/showthread.php?t=21458 X2 -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: January 9th, 2025 - 11:02 PM |
