> How can i fix this?, Camber angle
post Nov 23, 2006 - 3:10 PM
Slick
Joined Jan 10, '06
From Mozambique, Africa
I've read through some of the threads regarding the camber adjustment. There's been mention of camber bolts, but where do they go? does anyone have a picture shot of them installed? The angle is not off by much, and from what i've been told its within tolerance. but it annoys me. mad.gif the only suspension work that i've done is replace the shocks all around.
post Nov 26, 2006 - 12:26 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Crash bolts for the rears. Since you have an SS2... not sure if it has Super Strut fronts or not... but those are different. Crash bolts are those 'camber bolts' things... hehe... they replace the upper bolt on the strut casing and allow for some small adjustments to your camber.
post Nov 26, 2006 - 3:16 AM
hitcachi
Joined Jun 19, '05
From Nebraska
im pretty sure that you can get them at a dealership too. They arent too expensive.
post Nov 26, 2006 - 4:16 PM
Slick
Joined Jan 10, '06
Great! Thanks guys! I'm off work this week and one of the projects that i have planned is to take my car to the Toyota dealership for a review and service. unfortunately, we don't have very many celicas in country and the Toyota dealership is just about the only ones who know how to work on them. Yes, i know that its going cost me an arm and a leg! kindasad.gif I'm sure that South Africa would be cheaper, but they don't work on japanese import cars. mad.gif
post Dec 2, 2006 - 3:19 PM
jc47
Joined Nov 10, '06
From Cleveland
What makes you think the camber is not correct? You say it's been measured and fount to be within tolerance? If this is the case you shouldn't need to do anything; the tolerance is usually very small, and anything inside of the limits is good.
post Dec 3, 2006 - 12:19 AM
miro1975
Joined Nov 23, '05
From Charleston, WV
Camber bolts is the easy way to addjust camber. You can use them if you want to go higher then - 1.5. With bolts you can addjust camber up to -2.7. Simple and it works. Next step is camber plates. (around $250)
post Dec 3, 2006 - 11:32 AM
Slick
Joined Jan 10, '06
QUOTE(hitcachi @ Nov 26, 2006 - 10:16 AM) [snapback]505307[/snapback]
Well, the results from toyota was that they don't know what a "crash bolt" is! i tried to explane it to them but since i have to translate crash bolt to Portuguese, it must have been lost in translation. i also found out that they don't carry any parts for the celica! they have to order them from japan and it will take 1-3 months! Even oil filters! mad.gif
I guess i could order them (bolts) from the U.S. and would most likely arrive quicker, but i would need to know the correct part number for them. Anyone?
post Dec 3, 2006 - 11:40 AM
Rayme
Joined Feb 18, '06
From NB, Canada
eibach camber adjustment bolts is what you might need.
-Rémy
02 SiR, 08 250R
post Dec 3, 2006 - 1:20 PM
Slick
Joined Jan 10, '06
QUOTE(Rayme @ Dec 3, 2006 - 6:40 PM) [snapback]507385[/snapback]
Are these it?
Eibach Alignment Kit
post Dec 3, 2006 - 1:27 PM
Slick
Joined Jan 10, '06
Or these? if its these, although it states 1999 model, will they still fit my 94 JDM hatch?
Cam bolts
post Dec 3, 2006 - 1:56 PM
alaNi
Joined Nov 24, '06
From Kansas City
Lo-Fi Version Time is now: February 17th, 2025 - 5:56 AM
