st205 tranny mount on a s54 tranny???, my rear mount busted |
Nov 29, 2006 - 4:14 AM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
well my rear mount busted.
luckly i have the rear st205 mount and i was wondering if that would work? i got under the car and looked at the two and found that the st205 one looks like it will fit. however i also noticed that the mount that came with my gt for the s54 looks to be about an inch and half more to the passenger side (usdm drive) then that of the st205 mount. the brackets on the s54 tranny look like they will accept the st205 mount tho. i used the st205 front and side mounts as they had less miles on them but didnt use the st205 rear one because when i compared the two when the 3sgte was out they looked diffrent. has anyone used the st205 rear tranny mount with an s54 before???? does the offset not allow for the motor mount to be used??? thanks. |
Nov 29, 2006 - 1:33 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Nope won't work. It would work if you had the e153 tranny though.
Nov 29, 2006 - 3:26 PM |
lolo thanks i guess ill have to get another s54 mount blah...
will it not fit or just not work properly? This post has been edited by urbandork: Nov 29, 2006 - 3:32 PM |
Nov 29, 2006 - 8:31 PM |
Enthusiast Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
hey if u happen to never use that mount, hit me up i been looking for an st205 rear insulator and thats the only thing im missing.
bboy -------------------- ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Dec 2, 2006 - 12:47 AM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
I doubt you will be able to even fit it in and if you do it will make your motor sit very wrong...
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Lo-Fi Version | Time is now: December 4th, 2024 - 9:44 AM |
