Enthusiast ![]() ![]() ![]() Joined Jul 6, '06 Currently Offline Reputation: 1 (100%) ![]() |
okay so im going to finally be getting a new sub set up very soon, and i measured out the COUPES trunk, and its around 19 or so inches high. so that means the sub will fit.....but it also needs to be put in a box and that will take up some more room....i think it will be fine.......but does anyone know from personal experience...or know someone that i could talk to???
-------------------- ![]() KB |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
wrong section but it will be fine
oohh woops my bad sry
well with the box i think it will be a very tight fit.. -------------------- ![]() KB |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Kentucky Currently Offline Reputation: 5 (100%) ![]() |
I hope the coupe Trunk is nothing like the vert trunk. If it is...your outta luck bud. lol.
-------------------- ![]() Cuz Thats How Us Country Boyz Roll Growing up racing motocross, i learned one thing..."Always wear clean underwear, you never know when the Paramedics are gonna have to cut your pants off of you" |
Enthusiast ![]() Joined Oct 4, '05 From Rineyville, KY Currently Offline Reputation: 0 (0%) ![]() |
What's the length and width of the trunk? I'm sure you'll have no problem fitting a box for a 15 in there.
![]() Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) ![]() |
Just depends how much of a boot you will be left with.
easily fit a 15 but that also depends on how much airspace that particular 15" sub would need ![]() first newbie box just to give you a sense of size -> http://img206.imageshack.us/my.php?image=p...08medium4fe.jpg This post has been edited by soven: Nov 30, 2006 - 9:10 PM |
QUOTE(Mystify. @ Nov 30, 2006 - 9:01 PM) [snapback]506766[/snapback] What's the length and width of the trunk? I'm sure you'll have no problem fitting a box for a 15 in there. The length and the Width isnt a problem. its the height. -------------------- ![]() Cuz Thats How Us Country Boyz Roll Growing up racing motocross, i learned one thing..."Always wear clean underwear, you never know when the Paramedics are gonna have to cut your pants off of you" |
QUOTE(6th_celi_vert @ Nov 30, 2006 - 10:08 PM) [snapback]506773[/snapback] QUOTE(Mystify. @ Nov 30, 2006 - 9:01 PM) [snapback]506766[/snapback] What's the length and width of the trunk? I'm sure you'll have no problem fitting a box for a 15 in there. The length and the Width isnt a problem. its the height. How is it not a problem when finding the volume of a box is calculated by L * W * H? |
well....i think it should fit....but now i just need to find a good box
anybody know of any good sites for enclosures? and i cant find the exact dimensions i need for the woofer....its a type R 15'.... thsi si all i cna find ported: 1.5-3.0 sealed: 1.3-2.5 im not following exectalyl what hese numbers are standing for...deff not inches but does anybody actully KNOW FOR SURE if it will fit? -------------------- ![]() KB |
QUOTE(Mystify. @ Nov 30, 2006 - 9:12 PM) [snapback]506775[/snapback] QUOTE(6th_celi_vert @ Nov 30, 2006 - 10:08 PM) [snapback]506773[/snapback] QUOTE(Mystify. @ Nov 30, 2006 - 9:01 PM) [snapback]506766[/snapback] What's the length and width of the trunk? I'm sure you'll have no problem fitting a box for a 15 in there. The length and the Width isnt a problem. its the height. How is it not a problem when finding the volume of a box is calculated by L * W * H? I had to fight my 2 12's in there. There just isnt as much room as you would think. -------------------- ![]() Cuz Thats How Us Country Boyz Roll Growing up racing motocross, i learned one thing..."Always wear clean underwear, you never know when the Paramedics are gonna have to cut your pants off of you" |
well rihgt now i have 2 12's in there and i got them in quite easily....now they are ****ty subs and have a small box, but they went it easily....so maybe the vert trunk is smaller?
QUOTE(KB-2 @ Nov 30, 2006 - 10:28 PM) [snapback]506784[/snapback] well....i think it should fit....but now i just need to find a good box anybody know of any good sites for enclosures? and i cant find the exact dimensions i need for the woofer....its a type R 15'.... thsi si all i cna find ported: 1.5-3.0 sealed: 1.3-2.5 im not following exectalyl what hese numbers are standing for...deff not inches but does anybody actully KNOW FOR SURE if it will fit? I would recommend building your own box. If you're not confident in your woodworking skills, find a friend or somebody that is willing to help. Pre-made store bought boxes are universal and are not made for a specific sub (unless otherwise stated). Building your own box will allow you to put the subwoofer in an optimal enclosure given by the specs from the manufacturer. The numbers you put down are in ft^3 (cubic feet), this is the volume of the box. To find volume you need to multiply length x width x height. The measurements for length, width, and height can be anything just as long as the volume comes out right (unless it affects the mounting of the subwoofer i.e. not enough room for excursion or insufficient mounting depth). Bass is non-directional so you can have the sub firing in any direction (up, to the back, to the front, etc.) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
OmnipotentHammer has a 15" sub and it takes up every bit of space in his trunk.
well, i dont think i will be making a box anytime soon.
i was thinking i could mabye find one to be these dimensiosn online, or try to find someone to custom build me one.... so the box needs to be 3 cubic feet? -------------------- ![]() KB |
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) ![]() |
just get a good quality 12... venting space is needed and you shouldnt push that by using a 15
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) ![]() |
i push 2 10's...and its pretty loud
-------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
okay...waht would be a better set up
1 12' type R' on this amp...http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17203 or should i go for the 2 12's? on the same amp??? now i think i wnat the 12's becasue a 15' is gonna pretty much take up all my room. -------------------- ![]() KB |
one type r 12 on that amp would sound good... 2 on that amp could even work, but that would take a lot of space, and they would be a bit underpowered
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:55 AM |
