> rotor removal, bolt size
post Dec 5, 2006 - 2:02 AM
monky32
Joined Oct 19, '04
From orlando
does anybody know the bolts size if you want to pull out the rotors. i know it can be done with couple of bolts but i forgot the size. maybe 15 mm bolts?
post Dec 5, 2006 - 11:25 AM
The rotors should slide right off. But if you have to drive bolts into them to force them off, they're the same size as the 12mm bolts that hold the brake line to the strut.
post Dec 5, 2006 - 11:57 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
would some good ole pb blaster come in handy here?
post Dec 7, 2006 - 12:17 AM
monky32
Joined Oct 19, '04
From orlando
thanks guys for your help!!
post Dec 7, 2006 - 12:28 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
fronts bolts are 17mm, rear are 14mm
post Dec 7, 2006 - 12:44 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
if the bolts dont work, heat and hammer will.
post Dec 7, 2006 - 3:07 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(Bitter @ Dec 7, 2006 - 5:44 AM) [snapback]508583[/snapback]
No no - bad idea unless you are planning on trashing them anyway. My friend did this to his Corolla and man it was nasty.
BTW - I use 5/16-18 bolts I got out of stock at work and they worked great. Guess the thread diameter, pitch and threads per inch must have been very similar. Also worked well on another friend's Camry and Solara I work on too.
post Dec 8, 2006 - 12:19 AM
Bitter
Joined Mar 11, '06
well usually when you're taking off a rotor you'll be replacing it tongue.gif
also, you can always use a bar to hit the rotor hat to jar it loose.
post Dec 8, 2006 - 7:31 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Or to have it turned wink.gif . But yeah I see your point. It could be done with out destruction. The bolts will work for him though.
post Dec 8, 2006 - 12:09 PM
Bitter
Joined Mar 11, '06
i've stripped the rusty threads right out of many rotors and drums, the bolts work sometimes.
Lo-Fi Version Time is now: December 4th, 2024 - 4:29 AM
