> tranny question (3sgte)
post Dec 5, 2006 - 10:54 PM
sotos_94celica
Joined Oct 11, '06
alright guys i have a question... i wana do the 3sgte swap i read bout it but still not sure bout sum things... one which is the best tranny for da swap a lsd or non-lsd?? or would the awd tranny work?? and since my car is auto would i have 2 get a master cylinder for the 3sgte or for my car??
post Dec 6, 2006 - 2:59 AM
phattyduck
Joined Dec 5, '05
From LA, CA
An LSD tranny will be better than a non-LSD tranny. You can use a stock Celica GT manual transmission (wih the right clutch/flywheel combo), or an E153 (Camry V6 manual or MR2 manual converted to FWD). You cannot use an AWD transmission as-is. You can convert it to FWD only with the correct diff and a few other parts.
To run a manual transmission in your auto car, you will need a bunch of parts (new pedals, shifter, clutch master cylinder, clutch lines, mounts, etc)
That was a lot more than one question, by the way...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Dec 6, 2006 - 10:09 PM
sotos_94celica
Joined Oct 11, '06
yeah i know i jus had 2 find out... thanx for da info...
Lo-Fi Version Time is now: February 20th, 2025 - 3:22 AM
