> Bore out the 1.8 to a 2.0?
post Dec 6, 2006 - 12:27 PM
6gcSTVT
Joined May 3, '06
From New Hampshire
I saw that Igloo over in croatia (if thats how you spell it) rebuilt his motor completely and had it bored out to a 2.0 with new pistons etc. Is it cost effective or does it once again come down to the whole don't even try modding an ST unless its a turbo or engine swap. I assume only being a 2.0 it won't even push numbers that GT's have stock. Any other opinions?
Darin H.
post Dec 6, 2006 - 12:33 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well, you can add displacement a few ways.
you can bore the cylinder walls, go to much and you could be weakening the amount of power the walls between the cylinders can take.
you can lower compression, by having a shorter stroke or a lower piston height.
you can also add more material between the head and the block (ie over sized head gaskets)
personally id say if its turbo it might be worth it to lower the compression with low comp pistons and also bore the cylinders. but doing all that work for NA just isnt worth it to me. minimal gains.
post Dec 6, 2006 - 12:49 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
wink.gif if you want 2 liters, get a 3Sxx motor. the machine work to xray and bore the block would probably cost as much as a swap.
post Dec 10, 2006 - 2:30 AM
netrata
Joined Feb 16, '06
From Maui, Hawaii
yup, it would be the most cost effective solution. Why pay to change the 7afe's displacement when a 3sxx engine would be a better choice.
This post has been edited by netrata: Dec 10, 2006 - 2:33 AM
post Dec 10, 2006 - 4:36 AM
Nibbe
Joined Jan 6, '05
From Finland, Turku
Just go with some 3s motor. Like my friend put on 800 dollars to his '96 2.0gs eclipse and still cant beat up my celica. Its not worth it to spend money on a N/A especially when its possible to do a swap like 3sgte. Here in finland 3sgte swap isnt legal. If it would be legal i def had some st205 under the hood. Damn those stupid laws.
Please visit on our teams new website. hrp-tuning.com
19in deepdishes - invader bodykit - invader cf hood - x-box - dls audio
Lo-Fi Version Time is now: January 10th, 2025 - 4:52 AM
