> squeaking steering wheel?
post Dec 6, 2006 - 4:20 PM
Sh0gunkid8721
Joined Feb 22, '03
i was wonderin if anybody else had this problem? whenever it gets cold outside, somethin from the steering wheel orr somethin squeaks when i turn. its probably nothin major but its just annoying? any ideas?
post Dec 6, 2006 - 4:30 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
mine does that in the morning, only for like 2 mins though.
I don't think its coming from the steering wheel itself, I think its suspension parts or steering linkage in the engine bay that are greased up and the lube is just cold at first.
I <3 Dustin---07/16/06
post Dec 6, 2006 - 4:45 PM
nate95
Joined May 5, '05
From mattoon, IL
mine does it too when its cold, then goes away, nothing major i wouldn't think.
post Dec 6, 2006 - 4:46 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
I have the same problem for just a few minutes when it's cold. The noise I hear is definitely coming from the steering column.
post Dec 6, 2006 - 4:55 PM
Sh0gunkid8721
Joined Feb 22, '03
is there any way of gettin rid of it? i know its not major but its just annoying.
post Dec 6, 2006 - 8:08 PM
IdiotStick
Joined Jul 28, '06
From Moncton, New Brunswick
I too have this issue.
post Dec 6, 2006 - 11:16 PM
Remy
Joined Jan 25, '06
From MN
add me to the list too...hmm...weird....dunno why that happens though... kindasad.gif
"To Protect And To Serve The Wealthy" -POLICE
post Dec 6, 2006 - 11:23 PM
BluuFire
Joined Jan 4, '06
From Austin, Tx
I definately have this too... I belive that its just the power steering pump that makes the noise and its not a bad thing at all. Anyone who owns a GM car has that sound about 24/7 whether its cold or not. Definately nothing to worry. And as far as getting rid of it, i don't think there is any easy way.
This post has been edited by BluuFire: Dec 6, 2006 - 11:25 PM
post Dec 6, 2006 - 11:48 PM
D_Dawg
Joined Jul 22, '06
From San Antonio / georgetown, Texas
annoys me as well. i have this thing about lil noises like that, i cant stand it.
post Dec 7, 2006 - 6:49 AM
IdiotStick
Joined Jul 28, '06
My celica is full of littles noises so ive learned to live with it.
- Breaks
- Sway bar bushing in the rear
- steering wheel now
post Dec 10, 2006 - 5:37 PM
tomazws
Joined Oct 30, '04
From So Cal
Same here... let me add myself to the list =)
Usually when cold start, loud sqeeking made everyone turn head. After a I out of the parking lot, the noise's gone.
post Feb 5, 2007 - 4:09 PM
san0
Joined Aug 1, '06
From UK - Southern Central
Jeez, I thought it was rare, I'm on this list too!
You guys fixed it yet? Maybe grease the steering column.
Does it still squeek in wamer climates like 15 degrees+.
san0.:GT-SS2:.
post Feb 5, 2007 - 8:29 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Means you're low on blinker fluid...
post Feb 7, 2007 - 8:25 PM
alltracman78
Joined Aug 9, '06
From Ma
Not a problem I have but it's most likely the rubber boot on the bottom of the steering column.
Under the dash, where it goes through the firewall.
The metal shaft is probably squeaking against the rubber boot.
Spray silicone [or hardened] works well for this.
Grease will too, but the silicone is less messy.
post Feb 8, 2007 - 7:21 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(tomazws @ Dec 10, 2006 - 10:37 PM) [snapback]509352[/snapback]
That sounds more like a fanbelt mate.
As for steering wheel squeek, mine does it occasionally and its not loud just noticable. It is just near the top, I think it must be where the shaft goes through a bracket at the top. I'd think some wd40 or somthing sprayed on it would help but I just can't be bothered to take the column housing to pieces to get to it.
post Feb 8, 2007 - 9:45 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
i have the same problem for about 2 mins in the morning until i leave my apt complex and get the engine warmed up a little bit
Lo-Fi Version Time is now: November 23rd, 2024 - 7:42 AM
