> Electrical Upgrades?, adding another amp
post Dec 10, 2006 - 3:08 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
For you audio guys... I will be adding another hifonics 1200 amp so i can get 1 to each Type R... My question is what else should i do electrical wise in order to not run into problems down the road? I was planning on upgrading the alternator, but I think I want to avoid that for now... so should I add another battery just for the amps, or what options are there? Thanks for the help, I already have the 2.5 farad cap, but I know I will be having to add other upgrades to support all of the power being drawn.
post Dec 10, 2006 - 3:58 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
Upgrade the factory ground in the engine bay. Especially the thin one going from the battery negative terminal to the chassis. Run an appropriately sized power and ground cable for the amps. Ground amps to a clean part(sanded down metal that is part of the chassis). Upgrade battery if there is still dimming.
Lo-Fi Version Time is now: December 3rd, 2024 - 2:43 PM
