Power Antenna Wiring Problem, ***finally completed*** |
Dec 11, 2006 - 2:19 AM |
Enthusiast Joined Apr 16, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
hey guys, i'm just hooking up my head unit, problem is that in the original harness, there are two cable, however in my new head unit, there is only one. Now in the install doctor document, it said to join the two wires to the blue cable (new harness), well my question is, how does a single cable control the power antenna as compared to the original cables? does it send a pulse to raise and lower the antenna on the single cable?
Also in the secondary piece of harness(for the rear speakers) there is a small thin white wire with green stripe, not sure what this is, if u guys can point me in the right direction, it would be awesome, thanks I've got a Australian 95 ZR btw, thanks in advance guys This post has been edited by giang723: Dec 11, 2006 - 11:06 PM -------------------- |
Dec 11, 2006 - 2:29 PM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
If that is like USDM ones then you should hook up the one wire form the original harness that does plug into the back of the radio - that is the signal wire from the antennae to the radio. Then take the other wire and hook it up to the blue wire out of the back of the radio harness - this is the power wire for the antennae to make it go up and down. This is how mine is hooked up and it works like stock.
Dec 11, 2006 - 8:15 PM |
QUOTE(Negative @ Dec 11, 2006 - 2:29 PM) [snapback]509587[/snapback] If that is like USDM ones then you should hook up the one wire form the original harness that does plug into the back of the radio - that is the signal wire from the antennae to the radio. Then take the other wire and hook it up to the blue wire out of the back of the radio harness - this is the power wire for the antennae to make it go up and down. This is how mine is hooked up and it works like stock. thanks mate, i took a stab at it and combined the two wires into one and hooked it up to my head unit, amaazingly it works luckily enough lol but naywayz now i gotta clean up the mess i made in my car but the install doctor manual is awesome btw, i didn't need to go around searching for wires as much -------------------- |
Dec 11, 2006 - 11:04 PM |
Yep, just finished installing my head unit, it took so long cause this is my first time attempt at DIY, but anywayz here are the b4 and after shots, sorry for the pics being fuzzy
i so need to get a 5th gen cup holder or something to relpace the old cd player, instead of taking it out, leaving a gap, i just left it there until a replacement or some sought, but anywayz tell me what u guys think This post has been edited by giang723: Dec 11, 2006 - 11:05 PM -------------------- |
Dec 12, 2006 - 2:19 AM |
looks good...
you can always just get those universal DIN plates or pockets to fill in the gap of your old headunit. but would you have gone with a double-din stereo instead? -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Dec 13, 2006 - 2:41 AM |
QUOTE(azian_advanced @ Dec 12, 2006 - 2:19 AM) [snapback]509807[/snapback] looks good... you can always just get those universal DIN plates or pockets to fill in the gap of your old headunit. but would you have gone with a double-din stereo instead? yeah i thought about it mate, but i might get a dvd player if i had dosh, but highly unlikel, since i gonna save up for a second car in a few yrs -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 2:55 PM |
