3sgte 3rd gen oil type?, what do u guys use |
Dec 12, 2006 - 2:06 AM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
i was wondering what do other 3rd gen 3sgte ppl put in to their motor as far as motor oil?
Dec 12, 2006 - 4:03 PM |
im using 10w30
should i be using a heavier weight oil? 10w40 maybe? |
Dec 13, 2006 - 5:23 PM |
Enthusiast Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) |
I use silkolene pro s - 10w50
-------------------- 1994 JDM GT4 WRC
Dec 13, 2006 - 5:33 PM |
pretty much anything from 5w30 to 20w50 works fine. im using castrol 10w40 in mine right now.
Dec 13, 2006 - 5:51 PM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
I was considering using fully synthetic mobile 1 10w30. Anyone have any experience with this?
Dec 30, 2006 - 1:00 AM |
Enthusiast Joined Jan 16, '04 From sydney australia Currently Offline Reputation: 0 (0%) |
This is what i use in my 5sgte... -------------------- 312whp with more to come.... |
Dec 30, 2006 - 5:08 AM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
Either Silkolene Pro race R 10w50 or Millers fully synthetic 10w50....wouldnt touch anything if it wasnt fully synthetic, wouldnt go thinner than 10w50 either
Dec 30, 2006 - 12:17 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
I use mobile 1 10w 30 synthetic and have nothing but good experiences with it, along with the mobil 1 filter. I'm thinking of trying royal purple this oil change.
Dec 30, 2006 - 12:27 PM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
Wix filter and Mobil or valvoline synthetic 10w30
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Dec 30, 2006 - 2:00 PM |
the best filter to use is the standard Toyota filter, as it has a non return valve in it, and its usually as cheap, if not cheaper than other filters.
Dec 30, 2006 - 3:06 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(Insanity-74 @ Dec 30, 2006 - 2:08 AM) [snapback]514011[/snapback] wouldnt go thinner than 10w50 either That's just wasting hp unless you are only on the racetrack with your car. The motor was designed to run hundreds of thousands of miles with 5w30/10w30 oil (or 10w40 in hot climates). Says so right on the oil filler cap! -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Dec 31, 2006 - 8:43 PM |
You have to remember that these cars are getting old now and need a bit of TLC....10w50 offers a bit more protectionn to the aging internals...but each to thier own, run what you want.
Lo-Fi Version | Time is now: June 27th, 2024 - 12:22 PM |
