> e-153 tranny
post Dec 12, 2006 - 10:40 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
so i know ive read things about this tranny but how do you really make it work with the front wheel drive celica, when you get it outta the mr2. what years of camrys, solaras, and mr2s had this transmission because i cant ever find one that works with it. there is a i believe like a 95 MR2 at the local junkyard, will the tranny and parts of the axles in that work for the swap.
post Dec 13, 2006 - 12:26 AM
eggman40
Joined Aug 17, '04
From California
you will need to take the gear selector out of the awd tranny, then put it into the mr2 tranny. You will then need to have a shop weld the hole on the other side of the tranny up. Then you would need to drill and tap the holes for the shift linkages on the opposite side of the tranny so it works with the cables. I know this is a different language but you will need to go to this site and look at the write up.
as for the axels you will need to use the mr2 inner axles, (and carrier bearing on passenger side axle) and then you will need to use v6 camry Outter axles. Member Nemisis used 1990 outter axles, I used 1992 camry outters. Hope this helps. smile.gif
post Dec 13, 2006 - 8:46 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
QUOTE(eggman40 @ Dec 13, 2006 - 12:26 AM) [snapback]510050[/snapback]
ok so i understand the axles but your basically saying that it is alot of work to put the mr2 tranny in it, and its alot easier to put the v6 camry tranny in the car. also wut are you saying about the write up is that you mean like a sticky on 6gc. thanks alot for your help already.
post Dec 13, 2006 - 11:15 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
yes, there is a sticky on the mr2 issue, lots of work, but if you have the skills, tools, time, and money, its kinda worth while in the long run... the main benefit you get is a limited slip differential...
ive heard that while the camry tranny WILL work, its not a very efficient solution because of longer gearing ratios if im not mistaken... if ur on a budget, and just want to get it done, from what has been experienced the gt tranny is highly effective, and pretty durable...
Lo-Fi Version Time is now: November 27th, 2024 - 5:49 AM
