e-brake trouble? |
e-brake trouble? |
Dec 13, 2006 - 6:22 PM |
Enthusiast Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
hey guys recently had my one of my e-brake cable changed and now when i pull my hand brakes I only get three clicks and its tight but the problem is when I let go of my brake pedals the car shifts alittle and then it stops sometimes it makes a weird noise. Any thoughts guys thanks in advance.
Dec 14, 2006 - 7:42 AM |
Enthusiast Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
Think its normal mate.
when they changed it, sounds like the adjusted the cables. The pads on mine allow slight movement but then lock on full. Doesn't really make a noise but I can imagine its a slight grinding noise? |
Dec 14, 2006 - 1:13 PM |
sounds like it's too tight. Just adjust the cable yourself, it takes about 5-10 minutes andit's easy.
Dec 14, 2006 - 6:24 PM |
it does make a slight grind noise sometimes. and batman it does seem tight but they told me that is normal and it is good to have a tight cable then a loose cable and also how do I adjust the cable and is it easy cause im a dumbarse
Dec 14, 2006 - 9:15 PM |
ok real easy - should take 10 minutes or so.
first, pop off the shifter surround. Then take the center console off - 2 screws (arrows), 2 bolts in the console compartment, then lift it out with the ebrake up. Make sure you unplug the light to the ashtray before you take the console out. then it will look like this connected to the passenger side of the ebrake handle there is a bolt with 2 nuts on it (arrow) take the top one off (10mm) and loosen the other one (10mm also), then pull the ebarke up to see if you like how far up it goes. The more you loosen it, the higher it will go up. When you have it at the acceptable height, put the top nut back on and tighten it to the other. reassemble and you are done. Questions ? -------------------- |
Dec 14, 2006 - 9:29 PM |
how many clicks am i suppose to have 7-8?
Dec 14, 2006 - 9:39 PM |
Enthusiast Joined Apr 11, '06 From Tasmania Currently Offline Reputation: 0 (0%) |
Yes my handbrake was tight for the first few weeks but now its back to normal but i had no sound.
also sorry for highjacking but batman what is that box with the yellow cable. -------------------- Ok Gladys, lets play house, you be the door and I'll shut you.
Dec 14, 2006 - 9:43 PM |
QUOTE(celicaboston1983 @ Dec 14, 2006 - 9:29 PM) [snapback]510551[/snapback] how many clicks am i suppose to have 7-8? that should be fine. QUOTE(GreenyST204 @ Dec 14, 2006 - 9:39 PM) [snapback]510553[/snapback] Yes my handbrake was tight for the first few weeks but now its back to normal but i had no sound. also sorry for highjacking but batman what is that box with the yellow cable. SRS ECU -------------------- |
greeny when it was tight does it shift alittle on lil hills or dips?
Dec 15, 2006 - 2:05 AM |
I don't think it matters how many clicks you have to be honest.
Mine failed on the MOT cos it could be pulled all the way up (took alot of force to do it and normally 3/4 was enough to apply the brake) but the mechanic adjusted it and now mine will only raise about 2 inches, but providing it engages and disengages then 3 clicks will be fine. Why adjust it? |
Dec 15, 2006 - 9:07 AM |
as long as its connected somehow it'll engage at one point or another. adjusting it is really just for your own preference.
QUOTE(celicaboston1983 @ Dec 14, 2006 - 9:43 PM) [snapback]510557[/snapback] greeny when it was tight does it shift alittle on lil hills or dips? mine actually does this a little right now. my drum brakes didn't do it. I'm not too worried about it though -------------------- |
Dec 15, 2006 - 11:47 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(celicaboston1983 @ Dec 14, 2006 - 6:29 PM) [snapback]510551[/snapback] how many clicks am i suppose to have 7-8? my hayne's manual says it should be 4-7 clicks... mine has been rolling a bit on inclines too, and I counted my clicks today to be 10 when I first pull up the handle, and if I pull hard enough I can get 13 clicks out of it! I'm gonna try adjusting it tonight. I'll let you know how it works out. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Dec 16, 2006 - 1:23 AM |
ok, I'm done. I re-adjusted mine so it goes up about 6-7 clicks now, but if I try hard, I can pull it up to 10... oh well, close enough for me. it took maybe 15 minutes. it wasn't hard. just like batman said, take out the shifter surround, remove the two screws, remove the two 12mm bolts inside the armrest, pull out the center console, remove the one 10mm bolt, loosen/tighten the other 10mm bolt, replace the 10mm bolt, replace the center console, replace the bolts and screws, replace the shifter surround, you're done!
the only thing I had a problem with was getting the center console back. there are two little tabs sticking out the front of it that go into two holes on the other part of the center console. in order to get them in, you have to position the center console behind the other piece, lift up the rear of it, slide it forward into place, then lower the back end of it. it wasn't hard once I figured it out. took me like 5 minutes to get it back in. This post has been edited by 6strngs: Dec 16, 2006 - 1:23 AM -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Dec 16, 2006 - 4:18 PM |
are u still shifting a little before it locks?
Dec 16, 2006 - 5:31 PM |
QUOTE(celicaboston1983 @ Dec 16, 2006 - 1:18 PM) [snapback]511033[/snapback] are u still shifting a little before it locks? you mean when you pull up the e-brake, then let off the normal breaks and the car moves like an inch before it catches? I was doing that before, but after driving to several places today it hasn't done it, but I haven't parked on any steep inclines, but it didn't do it on any of the really gentle inclines I parked on. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Dec 16, 2006 - 5:36 PM |
QUOTE(6strngs @ Dec 16, 2006 - 10:31 PM) [snapback]511053[/snapback] QUOTE(celicaboston1983 @ Dec 16, 2006 - 1:18 PM) [snapback]511033[/snapback] are u still shifting a little before it locks? you mean when you pull up the e-brake, then let off the normal breaks and the car moves like an inch before it catches? I was doing that before, but after driving to several places today it hasn't done it, but I haven't parked on any steep inclines, but it didn't do it on any of the really gentle inclines I parked on. yea thats exactly what im talking about is that normal? the mech that fixed my car said its normal but my previous cars didnt do that and when it catches does it make a noise? |
Dec 16, 2006 - 5:59 PM |
QUOTE(celicaboston1983 @ Dec 16, 2006 - 2:36 PM) [snapback]511056[/snapback] QUOTE(6strngs @ Dec 16, 2006 - 10:31 PM) [snapback]511053[/snapback] QUOTE(celicaboston1983 @ Dec 16, 2006 - 1:18 PM) [snapback]511033[/snapback] are u still shifting a little before it locks? you mean when you pull up the e-brake, then let off the normal breaks and the car moves like an inch before it catches? I was doing that before, but after driving to several places today it hasn't done it, but I haven't parked on any steep inclines, but it didn't do it on any of the really gentle inclines I parked on. yea thats exactly what im talking about is that normal? the mech that fixed my car said its normal but my previous cars didnt do that and when it catches does it make a noise? I dunno, I always thought of it as normal, it never really bugged me. mine doesn't make a noise when it does it though. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Dec 16, 2006 - 6:51 PM |
i mean if it didnt make that creaking noise it wouldnt bother me but it creaks. and you can also hear it disengaging when I pull the ebrake down.
Dec 16, 2006 - 7:26 PM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
cool, just readjusted my handbrake so I do not need to pull it up as high now . Only takes a couple of minutes. My car moves an inch too before the ebrake engages on slopes.
Dec 16, 2006 - 9:55 PM |
QUOTE(celicaboston1983 @ Dec 16, 2006 - 3:51 PM) [snapback]511073[/snapback] i mean if it didnt make that creaking noise it wouldnt bother me but it creaks. and you can also hear it disengaging when I pull the ebrake down. mine creaks when I let it out too. just not when I pull it up... at least not that I notice -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Lo-Fi Version | Time is now: January 9th, 2025 - 1:14 PM |
