![]() Enthusiast ![]() Joined Oct 8, '06 From Jersey sHore PA Currently Offline Reputation: 0 (0%) ![]() |
Whats the differance between a side feed and top feed intake on a 3s
-------------------- 3sgte next year i hope
ummm the obvious that you stated in your question....
one has the FEED (aka throttlebody) on the SIDE top i think u misunderstood is more likely center which is in the center...aka stock |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
besides physical appearance. side = more even air distribution to the cylinders.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
also for our cars it really helps with intercooler piping, and it makes it so you dont have to run the intercooler piping over the hot engine
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(slow94st @ Dec 13, 2006 - 6:28 PM) [snapback]510266[/snapback] Whats the differance between a side feed and top feed intake on a 3s ![]() There's tons of information on the MR2 boards about both (manifolds and injectors) - it would be hard to write a summary of either here. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
![]() OEM CENTER/top FEED ![]() RMR SIDE FEED ![]() obviously he's not referancing injectors cause he stated manifold (thanx to john for pix) |
which manifold has more power potential. btw that rmr manifold is sweet
the stock one starts to become restrictive at what, like 350whp IIRC.
most any aftermarket manifold is ment to make more power, if they werent going to then they wouldnt produce them lol. they would just use the stocker. -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 2:58 AM |
