> Rear bearings, why... oh why do they have to be so expensive?!?
post Dec 13, 2006 - 11:09 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
ok,
Looks like i will be needing to replace my rear wheel bearings.
All the shops in town only carry the hub+bearing assembly. I have however found a wheel bearing module. It is only the bearing and not the hub and is at a fraction of the cost.... $300 for the assembly and $80 for the module.
I haven't taken apart the bearing/hub assembly and am not sure if I will be able to savage the remaining needed parts....
Need some wise info from all you gurus on the best plan of attack without killing my wallet!
post Dec 13, 2006 - 11:31 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
you could always go to a junkyard and try that.
post Dec 14, 2006 - 12:01 AM
advanced auto sells JUST the bearing assembly
http://www.partsamerica.com/ProductDetail....186&ptset=A
except the thing is toyota presses in the wheel hub then presses the hub and nut so you can't really remove it
not sure if you'll be able to tell from this picture what i'm talking about but at about "2 o'clock" you can see where there is a pressed notch thats what is extremely hard to undo
basically to seperate wheel hub from bearing hub = HUGE HUGE HUGE biznatch
This post has been edited by playr158: Dec 14, 2006 - 12:02 AM
post Dec 14, 2006 - 12:16 AM
LewFX
Joined Jan 28, '05
theres a few members parting put celicas, try one of theirs, you can put an ST hub on but you wont have your abs on.
post Dec 14, 2006 - 12:38 AM
phonex98
Joined Mar 25, '06
Im not sure what you are talking about... MY st has ABS ?
----- '94 ST hatch --- Yellow -----
post Dec 14, 2006 - 12:43 AM
LewFX
Joined Jan 28, '05
st hub will fit on a gt but doesnt have abs on it so your abs light will be on and unactive.
post Dec 14, 2006 - 1:23 AM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
^^^ Wrong, just that one wheel will be inactive.
post Dec 14, 2006 - 1:27 AM
LewFX
Joined Jan 28, '05
all 4 of mine locked up on me when i went skidding 40 feet to swerve out of the way of an idiot turning into me
post Dec 14, 2006 - 8:32 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE(celicast3sgte @ Dec 14, 2006 - 1:23 AM) [snapback]510343[/snapback]
WRONG, when ANY fault is found on the ABS system the whole ABS system is disabled.
post Dec 14, 2006 - 10:04 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(playr158 @ Dec 14, 2006 - 5:01 AM) [snapback]510312[/snapback]
it doesn't say if this has abs or not? anyone know. i did the st search and came up with the same part number. my car is a gt but no abs
post Dec 14, 2006 - 10:05 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE(Bitter @ Dec 14, 2006 - 8:32 AM) [snapback]510386[/snapback]
This is correct. ANY ABS fault detected will disable the entire system. A single tire locking up in a panic braking condition with the others still rolling woudl cause a sudden pull to that side, possibly causing loss of control.
post Dec 14, 2006 - 12:48 PM
QUOTE(rjbibeau @ Dec 14, 2006 - 10:04 AM) [snapback]510402[/snapback]
GT but no abs that hub will work..GT hub and ST hub are the same
its ABS vs NON-ABS that i believe is the difference...though i've only ever done hub work on NON abs cars so ive never seen the difference i'd trust my good friend lew on that info smile.gif
post Dec 14, 2006 - 2:52 PM
wind
Joined Nov 4, '03
all hubs ive seen are non-abs.
what do people with ABS do?
post Dec 14, 2006 - 3:08 PM
LewFX
Joined Jan 28, '05
the abs ones have a larger hole in the center with this spindle looking thingy on the end, it just lets the sensor know somehow.
post Dec 14, 2006 - 3:10 PM
QUOTE(LewFX @ Dec 14, 2006 - 3:08 PM) [snapback]510485[/snapback]
post Dec 15, 2006 - 3:43 PM
wind
Joined Nov 4, '03
has anyone that has ABS replaced their rear bearings?
post Dec 15, 2006 - 4:23 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i was just gonna ask the same thing. also has anyone ordered their rear bearings from that parts america place.
post Dec 15, 2006 - 4:36 PM
parts america = Advanced auto
so i'll probably be ordering set right after new years
post Dec 15, 2006 - 7:25 PM
Bitter
Joined Mar 11, '06
QUOTE(wind @ Dec 15, 2006 - 3:43 PM) [snapback]510799[/snapback]
yea, i bit the bullet and got one from a dealer, i couldnt find one with the abs tone ring anywhere else frown.gif
post Dec 20, 2006 - 7:25 PM
wind
Joined Nov 4, '03
Totoyta wants $470 (Canadian) each for ABS rear bearing + hub assemblies.....
Can anyone find me a better price?
Lo-Fi Version Time is now: November 30th, 2024 - 10:47 AM
