> Got a new engine
post Dec 17, 2006 - 11:07 PM
InfamousChappy
Joined Sep 30, '06
From Knox Vegas, Tennessee
So I had another 7afe dropped in after I threw a rod in the last one. Unfortunately, I have no idea how many miles were on this motor sooo...yea I have my doubts. What should I do to check on the shape of this motor? I'd like to build it up and turbo it. What things should I be looking for?
post Dec 17, 2006 - 11:15 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(InfamousChappy @ Dec 17, 2006 - 8:07 PM) [snapback]511280[/snapback]
a compression test on the cylinders is usually a good indicator to the condition of the engine.
post Dec 17, 2006 - 11:50 PM
InfamousChappy
Joined Sep 30, '06
QUOTE(6strngs @ Dec 17, 2006 - 11:15 PM) [snapback]511285[/snapback]
what kinda of place would be able to do this?
post Dec 18, 2006 - 12:29 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(InfamousChappy @ Dec 17, 2006 - 8:50 PM) [snapback]511292[/snapback]
any good mechanic. I'm not sure exactly what kind of numbers you should be looking for on a 7afe though.
post Dec 18, 2006 - 8:02 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
Not neccessarily so, my 7A-FE has 215 psi compression across the engine, and it burns oil like I own a oil well!! You need a leakdown test to help determine the health of the engine. I'm hoping stem seals will slow the consumption.
post Dec 18, 2006 - 8:16 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(56willysnut @ Dec 18, 2006 - 5:02 AM) [snapback]511360[/snapback]
I was taught that a leakdown test should be performed after a compression test and only if you had low compression in one or more of your cylinders... but I suppose it wouldn't hurt to perform a leakdown test as well. 215 psi seems really high though, my book for my automotive class says that most engines should typically fall between 130 and 180 psi. perhaps the 7afe is just supposed to have really high compression? now I'm curious as to what the manufacturer's specs say it should be...
post Dec 18, 2006 - 10:00 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
AllDatapro shows for a 7A-FE 9.5 to 1 compression, 192lbs or above for standard comp. 142lbs low, 14 lbs differential between cyls.
Lo-Fi Version Time is now: January 9th, 2025 - 10:42 PM
