noisy belt when a/c is on |
Dec 17, 2006 - 11:33 PM |
does anyone else belt make noise when you turn on the a/c?? i assume its the a/c belt.
Dec 18, 2006 - 12:37 PM |
Enthusiast Joined Jun 7, '05 From Corvallis, OR Currently Offline Reputation: 0 (0%) |
yeah, is it a sort of squeeking noise? 90% possibility its the a/c belt. You might be able to just tighten it, or you could buy a new one, they should only be a few bucks.
Dec 18, 2006 - 12:39 PM |
Enthusiast Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) |
QUOTE(tin_foil @ Dec 18, 2006 - 12:37 PM) [snapback]511408[/snapback] yeah, is it a sort of squeeking noise? 90% possibility its the a/c belt. You might be able to just tighten it, or you could buy a new one, they should only be a few bucks. X2 -------------------- Darin H. |
Dec 18, 2006 - 1:24 PM |
depends on the noise.......
belts don't make noise in general when they are in good condition This post has been edited by playr158: Dec 18, 2006 - 1:25 PM |
Dec 18, 2006 - 1:41 PM |
QUOTE(playr158 @ Dec 18, 2006 - 1:24 PM) [snapback]511417[/snapback] depends on the noise....... belts don't make noise in general when they are in good condition unless they're not tight, in which case they squeek. -------------------- |
Dec 18, 2006 - 2:24 PM |
which is covered by the "when they are in good condition"
reading comprehension > u the compressor if bad will also make a noise, and if yours has a clutch that could be the problem too.. even when the a/c is off the belt spins :rollseyes: so if it were loose it would make noise 24/7 which i'm not ruling out a loose belt.....too many of u e-mechs say its 1 thing...and u can't diagnose it down to 1 certain thing without actually seeing the car...so variety of options helps someone asking a question |
Lo-Fi Version | Time is now: January 10th, 2025 - 8:12 AM |
