Oversized tires with abs? |
Dec 22, 2006 - 1:35 PM |
Anyone running taller oversized tires and have abs? Any abs lights or problems? Ive heard on some cars it messes with the abs system.
Dec 22, 2006 - 2:18 PM |
Enthusiast Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
That could be possible.
ABS compares the speed of the vehicle with the turn rate of the wheels. Once your wheels stop moving and the vehicle speed is higher then 3mph the ABS kicks in..... larger wheels in diameter can throw off your vehicle speed |
Dec 22, 2006 - 6:14 PM |
how much bigger?
Jan 4, 2007 - 1:29 PM |
Enthusiast Joined May 17, '06 From Sweden Currently Offline Reputation: 0 (0%) |
Hie i run 225/45-17 on my -98 eurospec GT
and i have not notified anything strange?? the abs all seem to work well Rikard -sweden |
Jan 5, 2007 - 4:04 PM |
Enthusiast Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
The difference in speed with say a 17 inch wheel cannot be much than stock wheels at low speeds anyway. Maybe there is more of a difference at high speeds.
Jan 7, 2007 - 4:57 PM |
Enthusiast Joined Jul 23, '06 From Chester - UK Currently Offline Reputation: 0 (0%) |
any size wheel is fine if the rolling radius is the same as standard ie larger wheel use a lower profile tyre, so if you have changed this rule then yes it may effect the ABS rotation system.
-------------------- My Celica Is Now For Sale
Jan 8, 2007 - 5:04 PM |
Enthusiast Joined Jan 8, '07 From Sunderland UK Currently Offline Reputation: 0 (0%) |
QUOTE(Alex-UKSC @ Jan 7, 2007 - 9:57 PM) [snapback]515931[/snapback] any size wheel is fine if the rolling radius is the same as standard ie larger wheel use a lower profile tyre, so if you have changed this rule then yes it may effect the ABS rotation system. the abs is not affected so long as all wheels are the same diameter as the abs senses difference between the four wheels. |
Jan 8, 2007 - 5:40 PM |
Lo-Fi Version | Time is now: November 28th, 2024 - 6:55 AM |
