> Wot will happen, instrument cluster
post Dec 26, 2006 - 7:48 PM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
Hi
I brought some white instrument gauges for my speedo/rev counter am going to give a mate the instrument cluster to put them in.
But i was wondering if there are any negative effects on the car from not having the instrument pannel connected, as i really need my car for work but want the gauges put in NOW biggrin.gif ?
e.g. the ecu not getting all the right measuements or the altinator not charging the battery (i work in the country frown.gif )
I reaslise i might get a ticket and all that but just wanna know if it'll be bad for the car
Thanks
This post has been edited by beno: Dec 26, 2006 - 7:53 PM
post Jan 7, 2007 - 6:34 PM
fazz45
Joined Jan 7, '07
From Surrey UK
by the tme youve gone to all the trouble of dissasembling the dash to get the guages out you may as well spend the next five mins putting them in and putting the dash back together. shouldnt have any effect on the car as all the gauges do is display information, only thing is allow speedo cable to spin free unless its electrical connection. personaly i wouldnt drive it any where with out a speedo or rev counter, far too likley to get nicked in the UK, plus over here I think theres probably a law against it as you could be deemed to be driving without due care and attention or something else they could pin on you.
post Jan 7, 2007 - 6:52 PM
P5ycho
Joined Mar 29, '06
From UK
if u try driving without the instrument cluster in place, the ecu will put the car into safe/retard mode, as it relies on a pulse from the clocks to tell it the rpm and speed that u are travelling at, if the rpm puls is not present the ecu will kill power, and if the speed signal is not present the ecu retards ignition timing and puts the engine into safe mode,
efectively it increases fuel consumption and slows the car right down...
it will take u a total 10 mins to put the dash back together after fitting the dials so thats the route i would take...
Lo-Fi Version Time is now: January 10th, 2025 - 11:22 AM
