![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
hey guys... ive been having a problem with my gear shift from the moment i got the auto to manual swap done. it kinda grinds in 3rd, and all of a sudden it wont go into reverse AT ALL...
any suggestions? taking it to a tranny place tomorrow... This post has been edited by easternpiro1: Jan 6, 2007 - 9:00 PM -------------------- |
Enthusiast ![]() ![]() ![]() Joined May 3, '06 From New Hampshire Currently Offline Reputation: 2 (100%) ![]() |
Maybe the synchronizors (if thats how you spell it) are shot to hell... basically they guide the shifter into gear. Thats all that i can think of. good luck
-------------------- ![]() Darin H. |
probably somethings wrong with your shifter cables.
QUOTE(lagos @ Jan 5, 2007 - 1:08 AM) [snapback]515274[/snapback] probably somethings wrong with your shifter cables. yeah im going to take a look tomorrow... ive had times where it wouldnt go into reverse and i would hear some funny winding/grinding noise but now its as if reverse isnt even there its blocked -------------------- |
Enthusiast ![]() ![]() Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) ![]() |
Try to shift into reverse and slightly let go of the clutch but not all the way.
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(6gcSTVT @ Jan 4, 2007 - 11:00 PM) [snapback]515270[/snapback] Maybe the synchronizors (if thats how you spell it) are shot to hell... basically they guide the shifter into gear. Thats all that i can think of. good luck Synchro gears dont really "guide" the shifter into gear, but are secondary gears attached to the main gear that "synchronize" the shifting by speeding up that gear to match the engine speed. Essentially the same as double clutching. Worn synchros wouldnt be the case for reverse though, as the reverse gear is a straight cut gear (no synchro). That is why if your car is rolling a bit and you try to put it into reverse it will sometimes grind. |
so it may be a tranny th ing? im taking it to my friends import shop so we can screw with it, and find out..
try putting the car in reverse when the car is off. Does it go in then ? Then start it and see what happens
![]() call the doc and demand your $$ back !!!! ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) ![]() |
Does it go into 5th OK? I have a similar problem
whith my ae92 tranny except its 3rd grinding and 4th won't go in at all. Mine will go into 3rd at an Idle 50% of the time or so and forth is completely blocked out. I am going to check out the linkage on the tranny, oil level ect tommorow. I pulled my shifter already and checked my cables. -------------------- JDM guy made me do it.
i took it to a tranny place, for a free diagnostic. he said that he's thinking its something in the tranny maybe a broken syncro, a friend of mine that owns a shop said that the same thing happened to his evo but it was his 2nd gear and he told me my syncro may have gotten jammed in the reverse gear.
im going to have the guy pull the tranny out (doc said its a used tranny and dosent know the mileage) and have him rebuild it throw in an lsd and a lightweight flywheel while he's at it what do you guys think? -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) ![]() |
If i were you, i'd upgrade to a better/stronger tranny before you start rebuilding etc..
-------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
found out that i need new shift cables the ones in there were frayed. and i somehow managed to burn a new clutch up that was in there since october theyre going to go ahead and replace the blocker ring, and put in new bearings the gears look pretty good other than that REAL clean inthere.
anybody know where i can get some new shifter cables? ![]() -------------------- |
Enthusiast ![]() ![]() Joined Apr 25, '05 From nyc Currently Offline Reputation: 4 (100%) ![]() |
hit the dealer....when i got my new cables i think they came up to 150 or so....not that much. i just bought some for a friend from snapshotgt for a great price... not that that helps you lol
Yup, just sold some mint condition ones to rzanology for cheap.
![]() ![]() They are a high demand product, and unfortunately many junk yards cut them when messing with the motor etc... And when people have them for sale here they go really fast -- i had about 3 other people wanting mine. ![]() This post has been edited by snapshotgt: Jan 9, 2007 - 1:36 AM -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:04 PM |
